7.2 volt options
I have an old T-maxx I run for a stress relief. It has a 7.2vdc NIMH battery for the electric start. I want to convert this to a lipo or Life battery Just not sure what I should use??? 2s life or 2s lipo?
Pass you soon...
Pass you soon...
LiPo has a little higher nominal voltage (7.4V compared to 7.2V), while LiFe is quite a bit under (6.6V), on the other hand, LiFe aren't as delicate as LiPos (they're not known for turning into a fireball when handled wrongly, as LiPos certainly are.) Your choice, basically.
The voltage difference between LiPo and NiMH is not the problem though. Fully charging a LiPo and then only using a fraction of it at the track then after a while, not wanting to discharge it to storage level each time any more - that's the "danger" with LiPos in this type of application.
If one doesn't want to leave the LiPo at full voltage (4.2V/cell), then just charge it to something safe like 3.7V/cell or thereabouts. It'll be safe to leave it at that voltage level indefinitely, and there is more than enough energy and power available to turn over a starter. No need to overthink this stuff.
In which case you could also just use a LiFe battery (since you give away the LiPo's advantage of higher voltage anyway), with which you don't have to worry about charging it only half way each time (and keeping half of its capacity unused). Wouldn't call that overthinking - just thinking (which has never hurt anyone, by the way
).I do more than enough thinking at my day job and as a parent of two young boys to realize that it does indeed hurt (some days more than others).
