Like Tree245Likes
Tamiya TB Evo 7
Old 02-21-2020 | 08:44 AM
  #571
Looks like I'm going to have to add some weight.
rippen and walrusjon like this.
Jeff H is offline
Old 02-21-2020 | 08:51 AM
  #572
At least only 40g lol. Some cars like 100+ these days...
If you are already balanced L/R then under steering rack is good spot. Keeps close to center and is upfront
Jeff H likes this.
GimpyGolden is offline
Old 02-25-2020 | 09:25 PM
  #573
Hi TB EVO7 owners, I have just ordered one of these after a 30 year RC holiday.
I am wondering if anybody has tried all three motor positions and which configuration you prefer? I am tempted to go with the shorty set up because it works better with my OCD's. LOL
Thanks in advance for any responses.
Coops500 is offline
Old 02-26-2020 | 07:04 AM
  #574
I have only run A (front Motor) setup so far. On black carpet it works good. I am planning on trying B (rear Motor) but no plans for C (shorty) for me.
Would have to add much weight for VTA
Old 03-07-2020 | 11:55 PM
  #575
Default Shims
Just building my car after reading through this thread. Quick question. Does the kit contain extra shims? Building as per spec I probably have close to 3/4 of a mm play in the front gearbox input shaft.
Coops500 is offline
Old 03-08-2020 | 01:18 AM
  #576
I had to buy shims to take out most of the play.
Jeff H is offline
Old 03-08-2020 | 03:30 AM
  #577
rc_square24's Avatar
You might end up with a few extras but what I recommend is to get some 0.05mm thick 5mm shims to fine tune the gear mesh, such as those from Yokomo ZC-S50S, as sometimes +/- 0.1mm difference means being too tight or too much play.
rc_square24 is offline
Old 03-19-2020 | 08:17 PM
  #578
Default Setup advice
Hi all, built my car now ready for use when I return to the UK this summer if I survive the apocalypse.
Has anybody got any tips for 17.5 blinky indoors on carpet. The track is fairly small and tight.
I have the car built exactly as kit with the exception of some correct shimming.
I will be running 64p gearing. I have a 100 tooth in at the moment but think this is going to necessitate the use of a massive pinion to get a reasonable FDR.
Any thoughts, advice or info appreciated.
Coops500 is offline
Old 04-03-2020 | 01:21 PM
  #579
is evo 7 anywhere in stock online nowadays?
Duzgit is offline
Old 04-03-2020 | 09:55 PM
  #580
I got one from Rcmart and I believe they are still showing in stock.
Coops500 is offline
Old 04-04-2020 | 01:21 AM
  #581
CTE
We run aroubd 4.5 FDR for 17.5 blinky on an in ndoor sport hall carpet track at my club.
CTE is offline
Old 04-04-2020 | 03:08 AM
  #582
Unfirtunately it says backorder :/
Duzgit is offline
Old 04-05-2020 | 03:01 PM
  #583
If you really want to get your car dialed in. Get xray springs and sway bars and ditch the Tamiya stuff. Gear your car for the infield. Don’t worry about the short straight. Learn proper tire prep. You may end up wanting to use tire warmers to get the tires ready for the first lap. All Tamiya short springs are too soft for carpet racing
Jeff H likes this.
Juan Aveytia is offline
Old 04-17-2020 | 11:39 AM
  #584
*disregard*
Jeff H is offline
Old 08-31-2024 | 06:30 AM
  #585
Default I noticed that these are impossible to get today. Is anyone interested?
Let me know. I have one that has been build but never ran it.
kufman likes this.
rmont3 is offline
