Noob help!!! with 10.5T gearing-B5M
Im currently running a 17.5t motor in my B5M. Gearing is 31/69. I started running outdoors this summer and the tracks are a lot bigger. Overall my torque is fine but top speed is really to slow to keep up with everyone else. Without switching the gearing too much and running too hot, a lot of people recommended going down to a 10.5T or a 8.5T.
Here is my question:
Right now im running a 17.5T motor with gears 31/69 and a final drive ratio of 5.8:1. If I went with a 10.5T with 24/81 gearing, which is recommended by the manual, the final drive would be 8.8:1. So overall with the 17.5T i'd actually have more top speed since it has a lower ratio, is this right?......I might be off on my thinking here?? ( i know i can change the gearing but im just curious based off the "recommended gearing")
Basically my car has enough torque but the tracks im running on are pretty wide open, soft/dry, backyard style so i need more top speed. I don't think i can go up too much more on my pinion gear without my car running too hot. I thought maybe getting a 10.5T motor would do the trick buuuut i'm not sure?
A 10.5t motor spins at a much higher rpm then a 17.5t does therefore you have to gear down in order to keep it cool. A brushless motor has tons of torque already that's not going to be an issue. Your manual is going to be on the conservative side, I'd start with a 25-26 tooth pinion. I'd bet tree 26 will be fine.
okay so a 10.5T with lets say 24/81 gearing will have a higher top speed than a 17.5T with 31/69 gearing?
Right now im running an open class so it's more just for fun.
I have a Durango dex210. 99% sure we have the same internal gear ratio. I did with the previous gen AE cars. I run a 10.5 turn with 30/81 gearing and I am not fast enough down the straight on the open 8th scale shared track I race on. I could get there with a smaller spur which I don't have yet. I am running 140 in 20 Celsius weather.
