Tamiya mini cooper
https://www.facebook.com/TamiyaUSA/
More information on the M-07:
The materials used are no longer ABS plastic. Instead, we are using FRP (Fiberglass Reinforced Plastic), which is the same material used on our TA-07, TB-04, etc...
There will probably be CRP versions of the plastic parts someday.
Even better pics on Tamiyablog now.
It might not be the step forward in performance i had hoped. The long arms are not as long as on my old Xevo Triumph and the weight may not be as far forward as the M05. It's nice to see a modern style though and the gear diff and battery access should be better.
Just had a big race over the weekend and found my gearbox felt a bit notchy afterwards. I pulled the gears out and found a pebble stuck in between the counter gear and the diff. The gears are chewed a bit but are still usable in a pinch. Is there a replacement diff gear casing for the 3Racing diff, or do I need to get a whole new diff?
295Likes
