Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 02-03-2017 | 03:59 PM
  #5551
Finalist's Avatar
Originally Posted by FDDA15
Found a set of JConcepts B5m titanium turnbuckles in my spare parts bin. I see that the lengths are different by 4mm, anyone using these on their B6d?
Thanks!
I use the same. They are a better fit if you are NOT running short lengths. Less threads show if using the b5m JC fins on a b6 than if you used B6 on a b6.
Finalist is offline
Old 02-03-2017 | 06:49 PM
  #5552
Orion_2kTC's Avatar
Originally Posted by Jmuck69
Schelle will have the modified axles available this month to accommodate the 67mm axles. No need to machine or get the BMI inserts.
Sure and I just ordered the damn things.
Orion_2kTC is offline
Old 02-04-2017 | 08:18 AM
  #5553
AZJP's Avatar
Short answer on why and when different axles are needed?
AZJP is offline
Old 02-04-2017 | 08:33 AM
  #5554
New parts offer more rear grip. Seems mostly used when running the laydown trans on clay.
MX304 is offline
Old 02-04-2017 | 09:06 AM
  #5555
rvrslt1's Avatar
Originally Posted by jmcelroy42
Seeing the pics from the Factory Team drivers at the Reedy race, It looks like AE has something they're working on as well.
What would be the benefit of using the longer axles? I did see Kurt testing a few things... OCRC has them in stock now.
rvrslt1 is offline
Old 02-04-2017 | 09:56 AM
  #5556
longer axles or new hubs?
radioctrlhead is offline
Old 02-04-2017 | 09:58 AM
  #5557
I just got a 13.5 Orion Super Stock. 40 degree timing on the can using a motor analyzer, 4,000kv. Where should I start with gearing? Indoor shmedium size track.
chevmaro is offline
Old 02-04-2017 | 10:36 AM
  #5558
Your kit manual will have a starting point gearing combo depending on your motor. Start with that then tune motor and gearing according to track .
Phillip F is offline
Old 02-04-2017 | 05:17 PM
  #5559
How tight should the steering link ball cups be on the ball head thing. On my SC10 it is loose and moves freely on this it is snug
jpedersm is offline
Old 02-04-2017 | 10:31 PM
  #5560
Answering my own question here.
78/28 - 174 F
78/25 - 150 F
78/25 feels best.
And this motor is stupid fast. Recommended.
chevmaro is offline
Old 02-04-2017 | 11:29 PM
  #5561
78/28 - 174 F
78/25 - 150 F
78/25 feels best.
with or without fan? if that's with.. that's not good. If it's without..... add a fan.
Old 02-05-2017 | 01:32 AM
  #5562
Jmuck69, I got lucky and a friend has an extra set of hub inserts to move the bearings outboard... I'm planning to use the 5mm HEX hub to net a 0.5mm width reduction on both sides. sound reasonable?
basing this off of the Ray Munday setup sheets where he had better luck with the Narrow rear track width and use the pills on the bulkheads to narrow up the rear track. Hell some folks just ditch the stock 7mm rear hex and use 6mm (hard to find).
isn't narrow supposed to be worse for stability and cornering but better for speed?
twistedneck is offline
Old 02-05-2017 | 05:53 AM
  #5563
Cain's Avatar
The Yokomo springs were money! They felt softer than the setup that I was using, but offered the suspension action I was looking for on the track with the handling too.
Ended up qualifying second for the main but then got mauled coming out a double and was out of sorts at that point.
I am thinking I need just a bit more off power rotation but I think the buggy is pretty good to go.
I did go with "2" positions forward from rear most position on the battery with the VRP battery brace if that makes sense. That helped too with steering.
Also, using schuey staggers up front, jconcepts flipouts on the rear (we cannot used hardpin carpet tires on rear) and that combo worked well. Be curious if a slick in super soft could be a nice setup too.
Cain is offline
Old 02-05-2017 | 11:02 AM
  #5564
Dougefresh35's Avatar
Heres a little trick for you or anyone else who is running into this problem take a plastic wrapper that your parts come in and cut a little square out of it maybe a 1/2inch by 1/2 inch and place it over the ball stud then snap the ball cup over the plastic it will take up the slack or gap and feel nice and tight and wont bind up the turnbuckle 👍
Dougefresh35 is offline
Old 02-05-2017 | 01:07 PM
  #5565
rgrg2's Avatar
Default D mount
Is the aluminum D mount and inserts a good hop up to have? Is it much better for making adjustments?
rgrg2 is offline
