Types of Solder?
#16
My first thought is that maybe the wire has an enamel insulation coating. While I haven't come across that in battery leads, it's common in low-voltage audio cables (such as for headphones and microphones), and of course we see it all the time in motors.
My second thought is that the wire isn't copper.
I'd start by separating the wire into separate strands, and then gently scrape or sand the surface to remove any insulation or oxidization. If it has an insulation coating, you can also use heat to remove it (a solder pot is preferable, but I've used a small butane torch as a field-expedient methods); just be careful not to overheat the battery cell itself!
#17
http://www.frys.com/product/5841933?...H:MAIN_RSLT_PG
#18
This is the stuff I use. As far as I know it's proper leaded solder
MG Chem. makes a nice conformal coating I use to waterproof all my electronics.
#19
I would be lost without a frys near me lol. I get all my solder accessories from them. MG also makes awesome solder wick. I prefer it over a pump
#20
They do get sketchy sometimes and you have to watch out for the open box returns they try to seal up sometimes with a bit too much tape. Do they think we don't notice??
Solder wick looks fascinating and I'm still waiting for an opportunity to try it. You must do work on your receivers and escs as well to have experience with it?
#21
Yeah, just rub it in, why doncha?
I've never worked on a receiver before but I've had to desolder countless terminals on ESC's and the wick makes it a cleaner removal. Sometimes with a pump it creates little solder peaks that require reheating. And with the wick you just cut off a strip and slide it between the terminal and the iron and it soaks it up like a sponge.
It's also useful to remove excess solder if you used too much for pre-tinning because you can better regulate the amount of solder you remove. You end up with just enough solder to cover the posts.
#22
Your soldering iron is too hot. Oxidation happens faster at higher heat and you're burning the flux, preventing it from doing its job. I'm assuming your iron has an adjustable temperature because you said you use it on full. Set your iron for 550˚F to 600˚F (290˚C to 320˚C).
#23
#24
Lol yeah I hear you on that. Which is why I try to not buy anything major there. So laptops, video cards and pc components I usually get from Newegg or Amazon. Mostly I shop there for accessories. Like zip ties, hook and loop, wire retainers etc.
#26
