Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 12-27-2016 | 09:45 AM
  #4951
Matt Trimmings's Avatar
Originally Posted by B44
I think it maybe this #91605 cva axle shims
If you remove those and still plan on using the mip diff there is going to be an incredible amount of left to right movement in the diff. You would need to revert back to the stock diff/bones.
Matt Trimmings is offline
Old 12-27-2016 | 10:06 AM
  #4952
RC*PHREAK's Avatar
but if the bone is hitting the t-nut, removing those shims probably shifts the whole diff over enough to keep that from happening (well, doesn't stop it from happening but when it does, the whole diff moves so there is no bind). obviously not the way you want to handle the problem though.
RC*PHREAK is offline
Old 12-27-2016 | 10:15 AM
  #4953
Then you are going to shift the diff over when that nut hits the outdrive under power and I can bet the results aren't going to be good.
Old 12-27-2016 | 10:26 AM
  #4954
Azzkikin's Avatar
Anyone try the Imbue Brass pistons for the shocks?
Azzkikin is offline
Old 12-27-2016 | 10:30 AM
  #4955
I'm wondering if he is running the cv shims out on the axles in the carriers and removed them, not the ones on the outdrives.
Tijuana_Taxi is offline
Old 12-27-2016 | 10:47 AM
  #4956
Originally Posted by ridgerunner1
Our track is also high traction and i found that 7K in the gear diff is just right you may want to give that a try.
Tried 7K before on both my b6 and xb2 and considering its pretty cold in the track right now, the rear breaks loose coming out of ALL the corners , even just slightly giving gas exiting out a 90 or 180 degree. Reason I went to 4K....which helped a lot. I treed loosening the slipper but I would sacrifice snap to clear the jumps
francomang likes this.
Phillip F is offline
Old 12-27-2016 | 11:12 AM
  #4957
With the temps etc it may be wise to try a ball diff. I'll bet this looping out issue goes away or try to land right in the middle at say 5k diff fluid
Skeeter36 is offline
Old 12-27-2016 | 11:14 AM
  #4958
Reason I say that is in my experience you need a serious amount of grip for a gear diff to work in a 2 wheel buggy.
Old 12-27-2016 | 12:37 PM
  #4959
This is what I did wrong wording sorry.
MikeGassRacing is offline
Old 12-27-2016 | 04:18 PM
  #4960
So I have a nice broken in diff for a big race coming up but I want to turn tons of practice laps. I have a brand new gear diff I was wanting to run to learn the track. What gear diff oil should I use to be close to what a nice ball diff would feel like
Rcforlife13 is offline
Old 12-27-2016 | 04:55 PM
  #4961
GasGod's Avatar
anyone try alum shock towers? thoughts un these?
GasGod is offline
Old 12-27-2016 | 04:57 PM
  #4962
Thrifty's Avatar
Tight or loose... thick or thin... try 5000.. or split it with the 3 to make ya some 4
You'll spend more time taking the diff out than you will changing the oil. I have some 3000, 5000 & 7000 from my 1/8th buggy I've been experimenting with. But I also have an extra gear diff to prep with different weight for a quicker change if need be..
Thrifty is offline
Old 12-27-2016 | 05:05 PM
  #4963
Would using shock oil 100 weight or less be bad. Can u make a gear diff turn smooth
Old 12-27-2016 | 05:07 PM
  #4964
Hey love this thread and just getting back into things after being away for many years. I bought a B6 and went to the local track to see what the common specs and requirements were. The requirements are pretty relaxed and for stock some people are running 17.5t and some people are doing 13.5t. So my questions is: Would it be stupid to buy a 17.5t and 13.5t motor if I can get a deal? Initially I would like to take some time to get used to things again so I thought starting with the 17.5t would make sense...
gacbora is offline
Old 12-27-2016 | 05:13 PM
  #4965
Thrifty's Avatar
I'm not sure how shock oil weights stand against gear oil weights...
Thrifty is offline
