Tekno ET48 Thread >
Tekno ET48 Thread
Like Tree38Likes
Tekno ET48 Thread
Old 10-28-2016 | 09:56 AM
  #5056
Originally Posted by MX304
Nope. Tekin motor and esc. I guess the correct term with the new Tekin firmware is Torque control. I usually run 60% unless I am on a high grip track then I'll go to 80% or so.
Ah yes, TQ control...I think I'm at a 6 or 7...Don't remember. Kinda of one of those things that I set it and forget it.
ezlight is offline
Old 10-28-2016 | 10:01 AM
  #5057
Originally Posted by eXXon
What is the easiest way (or I should say how) to remove the front diff ?
Cheers.
Loosen the rear two screws on the diff from the chassis, take the front 2 out (2.5m's). Then take the screw out for the bumper (IIRC 2.5 also), behind the bumper are 2 long screws that go through the a block and into the diff housing. (2mm), I then usually take the 2 screws to take the sway bar bracket off. (2.5mm) And the 2 screws in the top of the front cover for the diff housing.
You should be able to wiggle the front cover off at this point, if not, loosen the 2 screws for the top plate of the steering<->diff, and that should allow enough wiggle room.
ezlight is offline
Old 10-29-2016 | 12:33 AM
  #5058
eXXon's Avatar
Will try it out tonight, cheers for the detailed reply mate, much appreciated.
eXXon is offline
Old 10-31-2016 | 08:46 AM
  #5059
BTW, STeps are almost identical for the rear. And also for every other tekno car.
ezlight is offline
Old 11-04-2016 | 10:12 PM
  #5060
LFR Assasian body
hawks is offline
Old 11-05-2016 | 02:53 AM
  #5061
LOW ET's Avatar
very nice!!!
LOW ET is offline
Old 11-06-2016 | 07:31 AM
  #5062
ROSCOE's Avatar
Can someone get me the length of the rear center shaft?
Thanks in advance.
ROSCOE is offline
Old 11-06-2016 | 09:59 AM
  #5063
Matthew_Armeni's Avatar
Thanks in advance.
85mm pin to pin.
Matthew_Armeni is offline
Old 11-06-2016 | 10:14 AM
  #5064
ROSCOE's Avatar
Thanks you.
ROSCOE is offline
Old 11-07-2016 | 02:36 AM
  #5065
hey guys have you seen the big price drop on towerhobbies i got a email from they dam
coombes is offline
Old 11-07-2016 | 06:20 AM
  #5066
justpoet's Avatar
Didn't know what you were talking about, so went to look at their website. Looks like they priced it $100 under what it should be. Get it while the gettin' is good! :-D
justpoet is offline
Old 11-07-2016 | 09:18 AM
  #5067
Something new must be coming but at this point besides hubs and springs what else can they change
Dragonfueled is offline
Old 11-07-2016 | 09:27 AM
  #5068
Judging by what changes they were running on the buggy at the worlds, I think we might see updated suspension geometry. New arms, chassis, hubs, shock towers etc.
MX304 is offline
Old 11-07-2016 | 04:04 PM
  #5069
justpoet's Avatar
Not quite sure where you're coming up with that from. The buggy has changed geometry in the past without an update to the truggy, because they don't share geometry in the first place. Towers didn't change, and different hubs are available already as an option part.
justpoet is offline
Old 11-07-2016 | 04:48 PM
  #5070
Yeah the buggy is allways being tweaked. The truggy has been great so i think they leave it alone.
