Problem Can it be fixed no soldering? >
Old 09-17-2016 | 09:04 PM
  #16
InsaneRC's Avatar
Originally Posted by blarks
Thats them.
Thanks for the help fellow RCtechers canceled other ones and placed order for those now it's a waiting game what fun
(Stupid Kindle stop autocorrecting)
InsaneRC is offline
Old 09-18-2016 | 07:12 AM
  #17
ta_man's Avatar
Originally Posted by InsaneRC
Wow this is all confiscated. I will probby GO the crimping route since it seems easier. Also I ordered this battery on EBay so I don't think sending back for repairs is going to work and the battery is this
http://www.ebay.com/itm/401189347965...%3AMEBIDX%3AIT
That is the new one I'm getting but different seller
So now I can get a crimp tool for 20$ on amain.com I hope this is the right tool for the job
https://www.amainhobbies.com/protek-...k-1999/p503208
Now I am having trouble finding the right pins and plugs. Of course when I get the new battery in the mail I can just copy the plug from there.
A servo lead crimping tool will not be able to crimp the terminals for the JST-HX balance connector. (Unless they made it too small to properly crimp a servo lead terminal.)
The length of the crimp area on a JST terminal is about 0.030", The crimp area on a servo lead terminal is about 0.075". So if you try to crimp a JST balance connector terminal with a servo lead crimping tool you will mash most of the JST connector.
ta_man is offline
Old 09-18-2016 | 11:24 AM
  #18
InsaneRC's Avatar
Angry
UGH.....could I use needle nose pliers? Can't cancel that order from amain now so I will be stuck with that tool at least if I have servo leads break or need to shorten them I have the tool for it...but if someone finds a cheap crimp tool that will work I might be able to save my ass and ruin the whole thing...
InsaneRC is offline
Old 09-18-2016 | 01:14 PM
  #19
ta_man's Avatar
If you have some needle nose with a tip only 0.030 (30 thousandths) wide you can try it.
I suggest that before you do it on your battery, you try to crimp a terminal on a piece of servo lead wire and then try to pull the terminal off. If you can pull it off, you have not actually crimped it and poor connection on the balance leads could have the charger misread the balance voltages and not properly balance the pack.
ta_man is offline
Old 09-18-2016 | 01:35 PM
  #20
InsaneRC's Avatar
Ok well I've been finding thousands of crimp tools but they all seem to read for servos. Just hope needle nose pliers cut it....
InsaneRC is offline
Old 09-18-2016 | 03:58 PM
  #21
blarks's Avatar
You may be able to get away with only putting the end of the terminal that needs crimping into the crimper, not the whole piece, will be fiddly but it should work. I usually close the gap a touch with the wire in there to hold it in place then crimp it. As Ta man suggested definitely try it on some scrap wires first.
blarks is offline
Old 09-18-2016 | 04:15 PM
  #22
InsaneRC's Avatar
I have a nice set of curved needle nose pliers that I am going to try and use and they don't have the jagged teeth like my straight one's are also I don't have small scrap wires I have 12g wires. Maybe if I have extra servo wires or something I could practice on. Anyone one want to ship me free wires?
InsaneRC is offline
Old 09-19-2016 | 03:23 PM
  #23
ta_man's Avatar
Go to the LHS and ask them for some wire from their trash pile.
If you want to send me a stamped SASE I'll send you some wire, but that's about $1 for two stamps when the LHS will probably give you some for free.
ta_man is offline
Old 09-20-2016 | 04:08 PM
  #24
InsaneRC's Avatar
sure think I have some spare wires just haven't looked waiting for the parts to come first take about a month since they are coming from China
InsaneRC is offline
Old 09-27-2016 | 02:51 PM
  #25
InsaneRC's Avatar
Well it took 5 connectors and 20 pins but I did it hope I don't have to do it again but the balance lead is real short too short I believe but everything is reading fine. Hope I crimped them good. Next time I'll just trash it or have someone fix for me.
InsaneRC is offline
Old 09-27-2016 | 04:18 PM
  #26
was going to say make sure to use a DMM and check every pin before you try and use it. First pin is always ground. You should be able to probe it easily
LVNeptune is offline
Old 09-27-2016 | 04:56 PM
  #27
InsaneRC's Avatar
What the hell is that? I tested each one works just fine it's charging right now.
InsaneRC is offline
Old 09-27-2016 | 05:11 PM
  #28
A DMM is a Digital Multi-Meter, you can use the multimeter probes to check the continuity of each connection.
Good job getting it done, but after 5 connectors and 20 pins it sounds like it might have been easier to solder it. Something else that can really make soldering easier is a small table top vice or a 'helping hands' setup for soldering.
mushroomed is offline
Old 09-27-2016 | 05:25 PM
  #29
InsaneRC's Avatar
I am planning on getting a good soldering station and some good jigs but I think I am done with soldering for now and also didn't use a DMM I just plugged into my blinky balancer plus my multi charger shows each cell voltages. So I think I did pretty good.
InsaneRC is offline
