Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 08-26-2016 | 12:24 PM
  #2851
Matt Trimmings's Avatar
Originally Posted by M2126
Planning to get a b6d. This is my first 10th scale 2wd buggy.
What are some basic must have upgrades to start? I'm planning to run stock class at ocrc. Anyone know how much weight savings the titanium screw set and the turnbuckles give?
Schelle Ti screw set will save about 15g, turnbuckles are somewhere in the 10-15g range I think. Uprgade wise I would get the aluminum D mount for more adjustments....that should be it.
Matt Trimmings is offline
Old 08-26-2016 | 12:25 PM
  #2852
jmcelroy42's Avatar
I put the AE Aluminum screws (for B5M) and AE Ti turnbuckles and MIP Pucks on mine and was right around 1450g.
jmcelroy42 is offline
Old 08-26-2016 | 12:26 PM
  #2853
egalsim's Avatar
Upgrades? Tracktime. It's fine the way it is.
egalsim is online now
Old 08-26-2016 | 12:32 PM
  #2854
Wildcat1971's Avatar
Tech Prophet
+1000000
I would say that is probably the best upgrade. way more tunability
Wildcat1971 is offline
Old 08-26-2016 | 12:37 PM
  #2855
racer1812's Avatar
Super Moderator
Which is right around 49g. under legal weight..
(about 10 nickles worth)
racer1812 is offline
Old 08-26-2016 | 12:50 PM
  #2856
mellow's Avatar
+1000000
The tunability this car has compared to the b4 makes my brain hurt. I'm still trying to wrap my head around all the different inserts for the c/d blocks.
mellow is offline
Old 08-26-2016 | 01:03 PM
  #2857
Ti turnbuckles are only about 8g by the way. Ill spend that $25 on tires. D block would gain you the most benefit. Only other thing i am really trying that i think will be noticeable is the long shocks in back and Scheme 31mm tower. Everything else is just perceived cool factor in my opinion
DG Designs is offline
Old 08-26-2016 | 01:34 PM
  #2858
do you have the part numbers for the D block and the 31mm tower?
thanks
M2126 is offline
Old 08-26-2016 | 01:39 PM
  #2859
mellow's Avatar
D block:
https://www.amainhobbies.com/team-as...c91688/p507425
Tower:
https://www.amainhobbies.com/team-as...c91666/p512484
Pretty sure you'll need the longer 31mm shock bodies though.
mellow is offline
Old 08-26-2016 | 01:43 PM
  #2860
thanks!
M2126 is offline
Old 08-26-2016 | 01:47 PM
  #2861
sorry, im pretty newb, do i need to get a new set of inserts for the extra tunability or do i use stock inserts?
M2126 is offline
Old 08-26-2016 | 01:48 PM
  #2862
mellow's Avatar
The kit comes with a set of inserts that you can use.
mellow is offline
Old 08-26-2016 | 01:51 PM
  #2863
great thanks, one more Q - for the longer shocks in the back, do i get both long shock body (31mm) and shaft? or just long body and stock shaft is ok? thanks again
M2126 is offline
Old 08-26-2016 | 01:54 PM
  #2864
Shaft is the same size for either setup.
Old 08-26-2016 | 01:55 PM
  #2865
mellow's Avatar
Shock shafts are the same.
As others have said though, if this is your first 2wd buggy, I'd recommend skipping the long tower and shock bodies for now, and put that money towards 1-2 sets of tires, and some spare arms.
mellow is offline
