Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 07-30-2016 | 11:17 AM
  #2116
Motorman007's Avatar
Thank you all on the servo post
Motorman007 is offline
Old 07-30-2016 | 12:04 PM
  #2117
Originally Posted by Schuie Driver
Making my way through the build and everything has been going very well. Kudos to Associated for making a pretty killer manual for this car. One problem I have run into though is my steering knuckles are pretty tight inside the c blocks. Did any of you run into this and did you loosen them up with a 3mm reamer?
if you mean the steering ballcups that connects the servo horn to the steering assembly... Then.. Yes. I just used a pair of pliers and flatten the ball cups a bit until it loosen up a bit.
Phillip F is offline
Old 07-30-2016 | 12:09 PM
  #2118
I'm pretty sure he just meant the steering knuckles.
boucher is offline
Old 07-30-2016 | 12:17 PM
  #2119
Originally Posted by 30Tooth
And you know why? The front suspension was collapsing more than the rear, now with the longer camber link the rear collapses as much as the front. It's like Usain Bolt having a sore knee so the medic would bang the good knee with a hammer so they're both hurting
That's the big problem with setup, which end is causing us trouble? Which way to go?
In the end, removing a shim (-1mm for a start) from the front bulkhead would be much better than a longer camber link. BTW, I've handled and analysed dozens of cars and most of them suffer from front suspension collapsing because of low RC height and generally too soft a spring too, that's why most tend to run too soft a spring and lower(or more roll) roll centers in the rear, compounding the issue.
Hope it helps!
I'll try this. Thank you.!
Old 07-30-2016 | 01:45 PM
  #2120
Originally Posted by Pistol123
Thanks, makes sense - will have to go away and have a think about those comments and get my head around it and try a different set up.
Please report back if you had success with the change in bulkhead shims.
30Tooth is offline
Old 07-30-2016 | 01:53 PM
  #2121
Mine were tight until I tightened the screws down all the way.
Sean B. is offline
Old 07-30-2016 | 03:59 PM
  #2122
Tried moving the shocks to the front, 1 in c block and half in d block. (a little more toe in and narrower) and the car is extremely easy to drive. When the shocks were on the back it almost felt like it made the car swing to much. Now it just feels planted
DG Designs is offline
Old 07-30-2016 | 04:22 PM
  #2123
AZJP's Avatar
"Lengthening rear camber links ".. You get + camber. Shortening it... You get - camber.
You change camber link length for roll, not for camber.
AZJP is offline
Old 07-30-2016 | 06:40 PM
  #2124
bprc10T3's Avatar
DG Designs what type of surface were you running on?
bprc10T3 is offline
Old 07-30-2016 | 07:32 PM
  #2125
BIGSKI15's Avatar
http://www.redrc.net/2016/07/schelle...ium-rear-hubs/
schelle updated the hubs to use with the kit inserts. I was thinking AE would update theirs too eventually.
BIGSKI15 is offline
Old 07-30-2016 | 07:42 PM
  #2126
Clay fairly high bite today. Sdrc. Kind of made me feel good that one of the fast kids asked if I had ever tried them in the back and that my car looked good. Finished 2nd in the main in my first race in about a year. I was always mid to back of the pack sportsman so 2nd is really good for me. I had fast lap as well. I lowered the front fill center just a little a picked up some steering in the 2nd heat and main and that took my fast lap from 19.8 to 19.2
Old 07-30-2016 | 07:54 PM
  #2127
Well, finally got the electronics in. Having trouble binding the receiver to the transmitter, but I'll tackle that tomorrow.
BruceR. is offline
Old 07-30-2016 | 08:40 PM
  #2128
Anybody actually racing outdoors with the B6D? The car is awesome but the shock towers are not well suited for dirt. We've already broken a front and rear which is something that never happened once on the B5M. I hope they make plastic versions soon. So far that's my only gripe.
QDRHRSE is offline
Old 07-30-2016 | 08:47 PM
  #2129
suby723's Avatar
So I just got done racing on a low/med bite track with my b6 laydown. I was the only one to even have a laydown car in the facility. I was very close on fastest lap times. I went to this race thinking my car was going to be undrivable and it completely exceeded my expectations. This laydown car can be successful on a low bite surface with the correct setup.
suby723 is offline
Old 07-30-2016 | 09:05 PM
  #2130
Jmuck69's Avatar
Plastic option towers would be cool.
Jmuck69 is offline
