Tamiya TT02 Thread
#1037
#1038
Originally Posted by eR1c View Post
Nope, my kit didn't come w/ the hardened parts (lighter grey color).
I ordered the TT-02D type S kit. ...it came w/ a lot of goodies, but not the hardened parts.
So, I am going to order that part, ...going to hunt it down. (I hate the large bumper piece sticking off the back).
It will not fit on the type-S as you have a different arm mount holding the suspension pins.
#1041
Since the weather will be hotter (here in Southern Italy temperature is 30-35°C), I'm thinking about installing a motor heatsink. I check motor temperature every 5 mins with an IR thermometer and I read about 40-50°C. Do you think I'll need an heatsink? Is it normal that it is hotter near the pinion?
#1042
if you are driving it in the street your ESC fan shouldn't need extra protection
In my tt02 I ran a 9t motor geared around with a 22 pinion. If you're concerned put on a heatsink + fan for it. You can get many from Rcmart. When I took my TT02 for rally on an off road track from memory it stayed around 60c with air temp in the low 20s within a 10 minute run.
I've never had issues with the ESC fan get caught with debris etc. Only had a fan die on me probably from shock when I ran indoor 4wd mod buggy... (the buggy hit the wall many times)
#1044
The TT02D Type S and TT02 Type S have identical suspensions, look at the regular TT02 and TT02D manuals and you'll see they're much simpler than the Type S variants.
#1045
#1046
Hey all. Wondering if someone can answer 2 question for me:
1. Can the smaller Mini Chassis rims/wheels fit on the TT02 or 01 chassis?
2. What is the narrowest you can get the chassis - outer edge of wheel to outer edge of wheel?
Thanks for your help
#1047
Sorry my post had a typo, the regular TypeS and D TypeS are the same suspension but they as a pair are a different suspension to the basic TT02 and TT02D (those 2 are also the same as each other). The central chassis, steering and transmission are common to all.
#1048
Well, I was thinking about something rigid like a plastic cover because my esc has a fan and I'm afraid a fabric could damage it or get sucked in.
Alfa Romeo TZ3 Corsa for USGT class. I attempted to do an Italian flag / stripe down the length of the body... as always, that nasty paint got under the masking tape.
1387Likes
