Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 07-18-2016, 05:43 PM
  #13426
oPAULo's Avatar
Originally Posted by foampervert
I like the Yaiba front suspension mounts the BEST! makes most sense, of all the aftermarket alu or brass mounts. Why cant hopup makers put in some brainwork when making hopups? instead of just making an alu or brass version of the original part...
after wrenching the rb5 for years, the yaiba front suspension mount was a huge and welcomed innovation I just had to transplant to to the rb6.
The Yaiba stuff certainly is pretty but they machine a little extra material out to make stuff lighter. Lighter is weaker. Also, I have a special gift for breaking RC cars.
oPAULo is offline
Old 07-18-2016, 07:25 PM
  #13427
rider313's Avatar
Trader Rating: 94 (100%+)
I broke the fancy rear camber link mount in 10 laps.
rider313 is offline
Old 07-19-2016, 05:21 AM
  #13428
foampervert's Avatar
Default Yikes!
That looks totaled! What j like about the yaiba front suspension mount is, it's grub screws are machines at an angle. I think the hole in the centre does remove some strength, which it will otherwise will have...
It seems like yaiba has stopped production of all the off road stuff... Buggy tech and requirements change with tracks... And high traction clay/Astro/grass/carpet tracks are now the norm. Having some weight towards the front is actually desirable.
foampervert is offline
Old 07-19-2016, 09:49 AM
  #13429
13Maschine's Avatar
Default RB6.6
I'm like a kid waiting for Xmas night with the new RB6.6! I'm considering selling my Xray XB2 and having a few K cars. I'll keep my current RB6 and convert to the RZ6 and run the new 6.6 alongside. My gf has recently picked up the transmitter and I think it would be a lot easier to manage two K cars rather than an Xray and Kyosho together. Really glad to see them include all the transmission options in one kit too. That's sick!
Did anyone pre order yet?
13Maschine is offline
Old 07-19-2016, 10:01 AM
  #13430
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Yes and impatiently waiting.
Kraig is offline
Old 07-20-2016, 11:23 AM
  #13431
I've pre ordered also. Going to run this car in 17.5, what would be a starting point on gearing? I'll be running on a medium sized high bite clay track. Thanks for any help on this, Dave.
Twisterdave is offline
Old 07-20-2016, 07:16 PM
  #13432
yodace's Avatar
Originally Posted by Cfconcrete
What's your rear track width? Is your battery sideways. Are you using McCune brace? Post your setup. This car make a ton of steering. Sometimes the rb6 can steer past what some can hold on to. Is it loose or does it rotate?
I think it was manly loose on power. The battery was sideways. I had the McKune brace but didn't screw it down. Was using the old electrons
yodace is offline
Old 07-20-2016, 07:41 PM
  #13433
oPAULo's Avatar
I run anywhere from 27 to 31 pinion on a 69 spur depending on ambient temperatures and the size and layout of the track. I've always read and heard to keep motor temps under 160 so I always keep an eye on that. I run a fan on the motor.
oPAULo is offline
Old 07-20-2016, 08:40 PM
  #13434
Thanks for the info oPAULo.
Old 07-20-2016, 10:42 PM
  #13435
likea45's Avatar
I race this car in stock 3 times a week and I spent quite awhile looking for the sweet spot of both good overall top end and decent torque. For my taste, I'm geared at 69/34 timing on motor set to 40*, Orion r10 punch set to 9(max).
Car is very fast this way. Good luck.
likea45 is offline
Old 07-21-2016, 02:58 AM
  #13436
oPAULo's Avatar
I think my temps would be cooking on that gearing!
I run a Motiv motor. Not sure on timing but it's up around 40. My car weighs 1600 on 2.2 wheels with steel drive shafts and stock 4 gear. We mainly run mod so I haven't put much focus on 17.5 setup. But, I did finally get a 3 gear built with aluminum pucks and ceramic bearings and going to try 2.4 wheels. Running it for the first time tomorrow.
Likea, what's your weight and drivetrain and opinion on 2.2 versus 2.4 wheels?
oPAULo is offline
Old 07-21-2016, 04:03 AM
  #13437
motorfinger's Avatar
Trader Rating: 18 (100%+)
I ran a hand wound Fantom 17.5 (the one before the new Fr1) and I was geared at 66/31. My car weighed 1510 grams and was a rocket. On our high bite clay I would carry the front wheels from corner to corner. Few people thought I was boosted or running a 10.5. I also had the light weight chassis(milled out for the sideway battery mod), pucks, slipper eliminator, a few titanium screws and ceramic bearings. As far as the 2.2 vs 2.4, I like the 2.2. I felt that the 2.2 gave me more grip. I know it sounds crazy and I probably am but that is what I felt.
motorfinger is offline
Old 07-21-2016, 04:23 AM
  #13438
oPAULo's Avatar
Not crazy. I actually had a Jcon sponsored driver recommend 2.2 for that exact reason. That was for mod buggy but now you have me second guessing. I'm going to snoop around the pits before I buy.
Thanks for your input mang!
oPAULo is offline
Old 07-21-2016, 08:25 AM
  #13439
Motorman007's Avatar
Trader Rating: 89 (100%+)
Man I trying to pick B6D or the kyosho RB6.6
I have the B5m Lite and all the stuff mip punk stuff and all.
and RB6 well 2 of them
So man this is hard. I need to see both of these kids in person and maybe wheel the b6d but i do love the idea of having 3 diff's If i read it right its 3 gear laydown diff's
Motorman007 is offline
Old 07-21-2016, 08:41 AM
  #13440
Super Moderator
Kraig's Avatar
1 diff with the car. Many different transmission options available in the box, 4 gear upright, 3 gear upright, 3 gear rear motor. With some extra parts, guessing a idler gear, 2 bearings and the shaft it rides on you can run a 4 gear laydown in the same space as a 3 gear laydown.
Kraig is offline
