Tekno RC EB48.3 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree22Likes
Last edit by:
Print Wikipost
Old 07-03-2016 | 10:08 AM
  #1906
Originally Posted by JOELD
I as well have this problem, did the pink springs come with the kit?
The Bornhorst setup uses pink front springs, not the black. With the black springs I can get 28mm of front ride height with the spring adjuster all the way down to the bottom of the threads. With the stiffer pink springs, the adjusters sit about 3-4mm further up the threads for the same ride height.
MX304 is offline
Old 07-03-2016 | 10:42 AM
  #1907
https://www.amainhobbies.com/tekno-r...kr6090/p274871
those juans?
JOELD is offline
Old 07-03-2016 | 11:08 AM
  #1908
Those are longer for the Truggy you need these ones for the buggy
https://www.amainhobbies.com/tekno-rc-70mm-front-shock-spring-set-pink-1.5-x-9.0t-2-tkr6035/p231833
crash n go is offline
Old 07-03-2016 | 03:25 PM
  #1909
I run 7-5-3 on my low grip dirt track as do all the fast guys using Mugen diff fluid.
What does PT diff oils stand for?
Slashn77 is offline
Old 07-03-2016 | 04:59 PM
  #1910
mkl
PT Oils are a brand of oil. They sell both diff and shock oil.
http://www.ptrcracing.com
mkl is offline
Old 07-03-2016 | 06:34 PM
  #1911
PT racing oil. It's thinner than most other brands so take that into account. For example 7-7-3 in PT oil is closer to 10-10-5 in AE oil.
MX304 is offline
Old 07-03-2016 | 07:45 PM
  #1912
8ight-e's Avatar
anyone have some time in w/ the universals? Seems like it will be a lot harder to clean with the inner bearing so far in the hub, leaving a lot more space for build up? Or does it stay pretty clear/clean?
8ight-e is offline
Old 07-04-2016 | 05:59 AM
  #1913
mxrcracer23's Avatar
Thinking of ordering a eb48.3, I was set on an eb48sl but I am leaning towards the .3 now. I am new to electric other than a 410.3 I just bought for the kids but I have kinda taken over. I was gonna go with the eb48sl so I could stay with the 2s batteries I had for the 410.3 but it seems as though a 4s system is the way to go with a buggy. My question is, will a hobbywing sct pro combo with the 2250 motor be enough to power a full sized 48.3. I will probably be ordering everything from fierce rc is the reason I'm curious about this combo
mxrcracer23 is offline
Old 07-04-2016 | 07:26 AM
  #1914
On 4S buggy systems, most will run the XR8 and a 1900 to 2100 motor.
qstorm777 is offline
Old 07-04-2016 | 07:28 AM
  #1915
PT told me Mugen visosity is about the same as theirs. However, I just runt the PT so I know I'm comparing apples to apples when looking at the team setups.
Old 07-04-2016 | 07:55 AM
  #1916
couple months and they seem fine, the bearing is deeper in the carrier so its protected better from the elements. I blew out at least four outer bearings in half the time ive ran since the swap, tekno did seem to have a bad run of bearings but to me it is better
JOELD is offline
Old 07-05-2016 | 04:41 PM
  #1917
proliteandsc's Avatar
Default oil question
I read AE oil is about 2k heavier then ptrc. How does mugen, ofna, and losi oil compare to ptrc?
proliteandsc is offline
Old 07-05-2016 | 06:31 PM
  #1918
Default Another oil question
Anyone know what the ptrc shock oil wt is equal to in AE, mugen, ofna, and losi. My LHS doesn't sell ptrc oil. They sell AE mugen ofna losi and kyosho.
Old 07-06-2016 | 08:16 AM
  #1919
Cain's Avatar
PT racing has a conversion chart on there site showing how Losi oil compares to there stuff.
May have your LHS order some for you?
Cain is offline
Old 07-06-2016 | 08:39 AM
  #1920
LutzRC has PT Oils
http://lutzinator.com/lutzrc/cart/in...k1n5fja3mp8of4
Bob Barry is offline
