Tekin ESC Tuning and Programing >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Last edit by:
Print Wikipost
Old 10-06-2016 | 11:09 PM
  #121
JAE
Randy Pike - Can you provide your setup similar to below for 17.5 stock buggy? I find the setup sheets don't have all the detail like below
Originally Posted by DamageNZ
Hey Randy - Below are my current settings:
Drag Brake Off
Brake Minimum 0
Active Brake 0
Brake Strength 100
Push Control 0
Brake Frequency 6101
Throttle Min 18
Neutral Width 12
Reverse Speed 100
Throttle Frequency 2007
Reverse Delay 0.76
Torque 10
Timing Profile 1 - Spec Stock
21.5t Fantom FR1 Motor running 35deg end bell timing
The only thing I have changed is the Tekin update, like I said the car just seems low on punch/power. Any advice would be greatly appreciated!
Cheers,
JAE is offline
Old 10-07-2016 | 06:56 AM
  #122
yzracer758's Avatar
Team Tekin
Originally Posted by SickNT760
Honestly I do not know how to set my brake frequency or how to even look at it. I have re calibrated my radio and ESC. Is the brake frequency done through the radio or is it something that I need the hotwire for? If the case is with hotwire I can order one and check to see if that may lead me to any further improvements.
The frequency will have to be adjusted thru the Hotwire. There are some other brake adjustments as well in the hotwire.
Curious if all the LED's light up and flash when you apply full brakes?
yzracer758 is offline
Old 10-10-2016 | 02:51 PM
  #123
Randy_Pike's Avatar
Team Tekin
Drag Brake Off
Brake Minimum 0
Active Brake 0
Brake Strength 100
Push Control 0
Brake Frequency 6000
Throttle Min 15
Neutral Width 5
Reverse Speed 100
Throttle Frequency 4000
Reverse Delay n/a
Torque 10
Here you go
Randy_Pike is offline
Old 10-20-2016 | 09:04 PM
  #124
NOFX's Avatar
Hi guys
Sorry if this has been covered and i've missed it but i I've got original tekin RS escs and a tekin B1. Firstly will v255 software work on them and secondly do the functions such as drive frequency work when the rs is running in brushed mode and on the b1?
Cheers
NOFX is offline
Old 10-20-2016 | 09:26 PM
  #125
NOFX's Avatar
Also sorry, I've read the FAQ and the 255 release wiki page etc and the hotwire info. I cant find if I am able to update the software on the Hotwire and therefore the esc using the android app or if i must use a PC by downloading the new hotwire program and updating that way
cheers
NOFX is offline
Old 10-20-2016 | 10:22 PM
  #126
JAE
Thank you!!!!
Originally Posted by Randy_Pike
Drag Brake Off
Brake Minimum 0
Active Brake 0
Brake Strength 100
Push Control 0
Throttle Min 15
Neutral Width 5
Reverse Speed 100
Reverse Delay n/a
Torque 10
Here you go
JAE is offline
Old 10-21-2016 | 06:51 AM
  #127
The new Hotwire 3.0 is going to be awesome, when does it go on sale?
MrLean is offline
Old 10-21-2016 | 08:19 PM
  #128
jason07's Avatar
I just received an android tablet from work but I don't have it right this second. (or the hotwire)
What cable do I need to hook the 2 together? Mini USB to Mini USB cable?
jason07 is offline
Old 10-24-2016 | 07:25 AM
  #129
yzracer758's Avatar
Team Tekin
What cable do I need to hook the 2 together? Mini USB to Micro USB cable?
Mini USB to Micro USB. I use this one: http://www.lindy-usa.com/05m-usb-otg...i-b-31717.html
Old 10-24-2016 | 02:12 PM
  #130
NOFX's Avatar
Originally Posted by NOFX
Hi guys
Cheers
Just to answer my own question, I was only able to update my tekin rs gen 1 to 223 software. I put it into brush fwd/brk mode and it works well however I found that the current limiter function wasn't saving so it was defaulting to no limit. That was all using a pc with the latest software downloaded, I'll try using my android to change settings and see if they stick
The B1 had the choice of 25 or 32 software I think it was.
Cheers
NOFX is offline
