Tekno RC EB48.3 Thread
#1756
I don't understand why there are so many grub screws on this buggy. This is my first 1/8 scale buggy build and I dont know if these are for tuning or to prevent the loss of parts if something breaks. The reason I ask is because I have no clue on which ones to tighten all the way or keep them loose.
).Is it common practice to Loctite all the metal to metal fasteners? I ordered the tekno and should get it this week. Can't wait to build it. Also trying to decide between the smc 4500mah battery or the 6500mah. Its about a 200 gram difference . Is the 6500mah gonna make the buggy handle different? Coming from 1/10 scale 200 grams is an elephant
Battery wise, 200g is nothing. These things are ballistic missiles
I tried the 4500 for a while, but honestly it's a pain to get it where you want to sit. If they made perhaps a short (height, not length), then I would try it again. So I would honestly just grab the 6500 of whatever manufacture you prefer.
#1757
Loctite and tighten down all the metal to metal grub screws. In fact, the ones on the front and rear diff, I would clean with brake cleaner, etc. to get all the oil off. The ones on the plastic hubs are used to hold the screws in (4 per hub, 16 total). They should just be tighten until you fell a little resistance like the manual says because they tighten up against the screw threads.
#1758
First day with the car and I love it. I started with the box setup so I could 'feel' that setup before moving to another. In box setup the car pushes some but is drivable, IMO.
Really impressed with how the car accelerates.. Like an idiot I didn't get the aluminum servo arm with the car and I stripped the stock plastic one.. other than that, the car is built proof so far..
I felt on high/medium bite the kit felt twitchy. But never ran it with a shock and spring change. Might have toned it down on more traction.
My 2 cents, lol
#1761
. I decided to put the center and rear chassis brace back in the car after replacing the drive-shaft. I figured if nothing else, I don't want that kind of chassis flex that allowed the drive shaft to bend like than and perhaps it would help the rear end of the car to rotate through the turns better. It was like a whole different car, it turned much smoother, was incredibly consistent and predictable and rotated through the turns like a dream. I did that after racing indoors which was on a higher grip surface. I was worried that when I went outdoors on a looser surface that the car might lack traction, but decided to leave my indoor set-up on the car for outdoors.
I'm hear to tell you my .3 is just dialed at this point. I know my set-up is running counter to a majority of them, but I feel like this car is soo much better with all the braces in!
#1762
Like a majority of the set-ups for this buggy, I ran without the center and rear chassis braces for a few months. I struggled to get the buggy to rotate through turns as smooth and quick as I prefer. My .2 buggy was much faster through a turn and I was chasing that same feeling. I tried heavier springs, higher oils, thicker sway bars, little to no anti-squat, camber link changes, shock location changes, etc. and I still felt like the buggy's rear was stuck to the ground. Then I squared off a metal poll at full wood and bent the front center drive-shaft in ways you can't imagine
#1763
hey guys, so im new to electric and just got this buggy coming from the nt48.3. im going to be running tekin 1900 or 2050 kv 14.8v 4s blah blah blah. my question is, im going to running high voltage servos ( savox or protek) do i need anything else to keep my electronics safe? or can i plug, charge and go? btw yes my receiver can take 7.4v. thanks
#1765
#1766
This is for me when I brake and turn, then want to throttle out straighter.
#1767
So I've rebuilt my one race day shocks 3 times and no matter what I do, the front end seems very 'springy'. I'm doing vented bladder. I've tried with no redound, 10% rebound and even 50%. It just seems very springy. No matter if I have the stock black springs or the pink. Any ideas? Rears are built with 0 rebound and feels very plush.
425 front with pinks 27mm height
475 reads with reds 29mm height.
#1768
Just a tuning option. I have never run the rear or center braces in my .2 or .3 and have never bent the chassis, or had any wear issues. The front brace has to stay in though no matter what.
#1769
Does it feel springy on the track, or just on the bench?
22Likes
