Tekno RC EB48.3 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree22Likes
Last edit by:
Print Wikipost
Old 05-17-2016 | 01:02 AM
  #1621
werner sline's Avatar
Lift the diff up off the chassis ? what's the point ? isn't the front driveline already perfectly in line ? the rear little dogbone is not lined with the diff so rising the diff would be worse
or did I miss something ?
werner sline is offline
Old 05-17-2016 | 01:53 AM
  #1622
shannow's Avatar
Seems to be that people lift the diff up but lowers the camber link holes to accommodate.
I don't see much reason driveline/geometrically wise but what it does is lift the whole shock tower up thus moving the endpoints of the shocks further up (less droop and more compression available). Also limiting the droop through the shocks rather than the wishbone is a much better and stable solution.
Well that's what I understood.
shannow is offline
Old 05-17-2016 | 03:27 AM
  #1623
oh they lift up the REAR diff ! ok, it clearly helps the poor little dogbone ! but otherwise, I don't get it too
Old 05-17-2016 | 05:55 AM
  #1624
Ok so the diff mod. What we are doing is raising the diff so that it creates more mechanical bind in the outdrive. This will lock the rear in, especially on power coming out of turns. When you do this mod, you have to lower all of your rear inner pivot points IF, and I say IF, you want to keep the exact same geometry. There is no MUST RUN setup for the inserts and camber links, but the team has tested it a ton and found the best starting point to be the 2 hole for the camber link on the tower, 1 dot down for the C Block and 2 dots down for the D Block.
Here's a link to the shims. https://www.3dgydesigns.com/collecti...-5mm-and-2-5mm
I'll be attending the Rumble in Rome race at CRC June 3,4,5 and can demonstrate the shims. I'll also talk to Mike about giving me a few in case you guys want to buy them.
Bob Barry is offline
Old 05-17-2016 | 06:40 AM
  #1625
goehm's Avatar
So, any setup sheet posted on TeknoRC.com is without the shims? I assume it'd be in the notes section if it was being used. I just got a 48.3 and am trying to come out of the gate with a decent setup. Thanks Bob.
goehm is offline
Old 05-17-2016 | 06:48 AM
  #1626
Correct. To my knowledge, NO setups on the site include the shims or arm mods unless specified in the notes.
Start with Joe's Southern Nats setup or Wicked Weekend setup and you'll be very close.
I have been running the Wicked Weekend setup but just switched to 4x1.8 pistons and liked it better. I have the 3x2.1 in my NB and it was awesome. I haven't put them in my EB yet, but I will try them eventually.
Old 05-17-2016 | 07:25 AM
  #1627
Originally Posted by Dog Runner
I'm new to Tekno (just ordered the eb48.3!) and read through this entire thread but don't see details of this diff spacer mod. Did I miss it somewhere? Can someone point me in the right direction for where to find what this is and how to do it?
For batteries, I see that Joe's setups are typically with 6500 batteries while Ryan's are mostly 5000. That seems like a pretty big difference in weight between those two sizes that would affect the setup. Is there a recommended battery weight that works best in the eb48.3 or does this difference in weight not really affect the buggy that much?
I run SMC 5200's in my EB48.3...and SMC 6700's in my ET48...The 5200 balances the car more..from what I've read...as far as noticeable difference in handling, that I cannot tell you. For a while I ran the 3600mah 2s sized 4s...I decided to just match the the batteries so that there was no difference. Never really made a mental note as to which battery was in it when I was running it with the different weights.
ezlight is offline
Old 05-17-2016 | 06:06 PM
  #1628
Good discussion on the shims, could someone please explain the "mechanical bind" that is created and how it changes/helps the car? Thanks guys.
Scott
rccars4scott is offline
Old 05-17-2016 | 06:31 PM
  #1629
that diff shiming seems serious !
so you rise the FRONT diff to "brake" the front wheels when on power. so the center diff might give more torque to the rear diff
that's some fine tuning !
Old 05-17-2016 | 06:33 PM
  #1630
I would rise the REAR diff so that the rear dogbone gives all the power from the center diff without any loss
Old 05-17-2016 | 07:53 PM
  #1631
I love the 6 x1.5 37 rear 32 front oils
Fuzzchop is offline
  #1632
Default vrp pistons
I love the 6 x1.5 37 rear 32 front oils with vrp
Fuzzchop is offline
Old 05-17-2016 | 09:36 PM
  #1633
Matthew_Armeni's Avatar
The diff shimming is to create bind in the rear driveshafts, the ones that go into the hubs, not the center driveshafts.
Matthew_Armeni is offline
Old 05-18-2016 | 12:20 AM
  #1634
suzukipro's Avatar
Any chance there will be a an updated rear diff from Tekno to accomplish this?
suzukipro is offline
Old 05-18-2016 | 03:41 AM
  #1635
Thanks for the reply, I should have been more clear, what effect on handling does the added binding provide. Sorry for the questions, coming from an oval background and I am trying to learn off road set up.
