Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree141Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 04-14-2016, 03:26 PM
  #26881
I prefer mine set to 2 inch lift. It really depends though. I tried the Direct Drive and it was snappy for sure. But it was abusing my diff and pucks. I prefer a slipper to save my drive terrain and make the car easier to drive. But some guys like them loose and other like them tight.
Speaking of Schelle Slippers and lift. I just finished my b5M (1st car since 1988), and installed the Schelle slipper during the build. So 2 days ago I went through the diff break-in per the video in this thread, and then tried the Slipper setting per the same videos, but I couldn't get any lift at all. I tightened it as far as I could go ans still no lift. Any idea why? Running the Hobbywing XR10 Justock, an EcoPower Slingshot, and have the Airtronics MT-4. My battery is a Team Trinity 2s 80c (3400mAh).
Maybe I need to adjust the ESC "punch" setting, I left it at the default. Also, the battery wasn't fully charged. It was only in storage mode.
Not sure if those two things will make a difference?
Thanks in advance.
40yoCaliRacer is offline
Old 04-14-2016, 03:28 PM
  #26882
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
Thanks in advance.
There is your answer right there.
Matt Trimmings is offline
Old 04-14-2016, 03:38 PM
  #26883
Ahh thanks. I haven't charged the battery fully yet, I still have to paint the body. I did run it body less outside for a few minutes and it was very fast. Guess with a fully charged battery it will be faster.
Guess I can try that tonight.
Old 04-14-2016, 06:25 PM
  #26884
what are some good battery suggestions?
eddie7978 is offline
Old 04-14-2016, 07:15 PM
  #26885
Kalio's Avatar
I've been wondering about batteries too. I thought about getting the ProTek RC 2S 100C X-Light Shorty LiPo because the weight is only 147g (vs ~210g for most shorties), but the capacity is only 2800 mah and one reviewer commented on relatively high IR. I'm not sure if the big loss in capacity is worth it the weight savings. I presume a lower capacity battery will loose more punch quicker then a higher capacity (4000-4500 mah) battery, especially in a 10 minute main.
Kalio is offline
Old 04-14-2016, 09:58 PM
  #26886
tsair's Avatar
If I go from 2x1.6 pistons, 32.5wt AE oil up front to 3x1.4 pistons, anyone know of an approximately equivalent wt. oil? Maybe AE 30 wt.?
tsair is offline
Old 04-14-2016, 10:58 PM
  #26887
If my maths is right you will need 37.3wt to keep the same effective damping.
4SFED is offline
Old 04-15-2016, 06:15 AM
  #26888
Trader Rating: 61 (100%+)
I also prefer to give my money to the guy that designed it in the first place.
So you buy from Avid?
Socket is offline
Old 04-15-2016, 06:50 AM
  #26889
SamuraiJack's Avatar
Trader Rating: 41 (100%+)
Hello! Could someone do me a huge favor and measure the exact distance between the holes (center to center) on one B5M wing mount? Thanks
(Between the two vertical holes on one mount for mounting on the shock tower)
SamuraiJack is offline
Old 04-15-2016, 07:15 AM
  #26890
JC8390's Avatar
I've been eye balling that battery for a while. I think it would be a good way to go because if you wanted to put weight back in for whatever reason swap the battery to a heavier one and done.
I could see it being close in a 10min main but it should be ok. I'm sure it would loose some kick towards the end.
JC8390 is offline
Old 04-15-2016, 07:17 AM
  #26891
Originally Posted by SamuraiJack
Hello! Could someone do me a huge favor and measure the exact distance between the holes (center to center) on one B5M wing mount? Thanks!
I'm getting 23mm.
Gearhead82 is offline
Old 04-15-2016, 07:21 AM
  #26892
DennisNyholm's Avatar
10 min main? That sounds like fun. I'm getting about 15 minutes on a 4200 pack, don't know if I would make it with that battery myself. Luckily I'm good on weight so a shorty is perfect for me.
DennisNyholm is offline
Old 04-15-2016, 08:11 AM
  #26893
JC8390's Avatar
I don't see 2800mah being a problem at all for 10min. I generally use about 1000mah in 5min.
JC8390 is offline
Old 04-15-2016, 08:21 AM
  #26894
I don't like the idea of making the battery lighter. This is your heaviest part of the car, and is a well used part for weight bias. Lose weight there, you also lose your ability to balance the handling.
Socket is offline
Old 04-15-2016, 11:31 AM
  #26895
has anyone treid the reedy lipo 5300?
