Tamiya mini cooper
Finally got around to make the front camber arms on my M03. Basically took the same idea I did on the M-Four. Two short ball connectors chopped off about 1mm each, 8mm set screw inside. Used a few bushings to position the arms properly on the M03.
Car is dialed with -1 camber, not the ridiculous amount it came with out of the box. At least on my track no need for that much camber; not only did it not have the stability I wanted, it also ate the tires too fast on the inner treads.
http://www.rctech.net/forum/members/...r-arms-top.jpg
http://www.rctech.net/forum/members/...amber-arms.jpg
M03 front droop control..
http://www.rctech.net/forum/members/...op-control.jpg
And no, there is no noticeable stabilizer action as there is nothing holding the bar on the top side of the 2 screws holding the bar in place. I have a dedicated stabilizer installed on the aft side of the arms.
Would these body post binder help you?
http://www.amazon.com/3Racing-M05-32...iya+m-05&psc=1
This is what I have from my M05 that I no longer use. The 2nd hole from the outside is perfectly spaced with the Rover Mini body pre-drilled holes as I found out.
I just need to make a bracket from the base of the damper stay to the chassis which shouldn't be too hard to do. http://cdn.rcmart.com/images/tamiya-54475-1.jpg
So, what did you guys get for your RC cars this xmas?
I bought myself that BSR M-Rage I mentioned, along with 2 sets of Shimizu 55mm tires with Tamiya Rover Mini wheels for each m-chassis, receivers, ESC, servo's for the parts bin. Also got a small box of spare parts for my SabreMini's. I'm still waiting on a couple more things to come in from Japan.
From family I got some cool gifts, but they are non-RC related. They want to pull me out of the basement I guess.
This entire week I spent most of the day working on my RC cars with my kids, will do the same entire next week since I'm off for 2 full weeks this holiday.
Hope you all have a great holiday.
This entire week I spent most of the day working on my RC cars with my kids, will do the same entire next week since I'm off for 2 full weeks this holiday.Hope you all have a great holiday.
New radio for my b-day a few days ago. We and the rest of the extended families are putting Xmas money towards charities and food banks. We already own a lot of stuff and are too fat! It'll just be great spending time together (and eating some turkey). Merry Christmas, guys!
Is there such thing as a gear diff (oil diff) specifically made for the M03?
I see gear diffs for M05's..but I'd like to install one without boring out holes if possible.
I'm already noticing my MantaRay diff is starting to loosen up only after maybe 50-60 runs?
I'm just hoping someone offered something in the 15yrs I was away.. lol TIA
295Likes
He had the lipo version too.
