Engine bearing removal/install tool >
Old 11-01-2015 | 08:58 PM
Default Engine bearing removal/install tool
Which bearing removal tool will you recommend?
Thanks.
Ted Su(TW) is offline
Old 11-01-2015 | 09:36 PM
dameetz's Avatar
Thanks.
Hudy
dameetz is offline
Old 11-01-2015 | 11:16 PM
Thanks for your reply.
Almost pulled the trigger on the Novarossi ones, but read from somewhere that it only pulls the bearings out, can not install them.
Not sure why they came up with a bearing puller only, and no installer.
Old 11-02-2015 | 05:55 AM
i use KM,cheaper and come with removal and intaller complete set
kyosho malaysia is offline
Old 11-02-2015 | 06:29 AM
But I think the KM ones are discontinued.
Old 11-02-2015 | 07:08 AM
Hudy engine tool kit is one of those tools that when you use it once will never go back for another tool. IMHO it worth every penny.
danyvw is offline
Old 11-09-2015 | 12:26 AM
I got one hudy bearing tool for sale. Used one time👍🏼😃
Autod is offline
Old 11-09-2015 | 05:13 AM
blis's Avatar
+1
The same Hudy tool does both .12 and .21 engines but come only with one of the collars, so be sure you get the right one.
After too many years with oven gloves, I used a heat gun and the tool and a huge sigh escaped me from all the stress doing it the old way. It's lovely to use and good for your engine.
blis is offline
Old 11-09-2015 | 05:23 AM
Originally Posted by blis
+1
I had the same experience. Many years using the oven, reluctant to spend $100 in that tool, one day a friend that had one showed me how easy he removed the bearings from his engines. Bought it and never looked back, now it's almost a pleasure to remove/insert the bearings on my engines. I also use a heat gun to make things smooth.
danyvw is offline
Old 11-10-2015 | 05:26 AM
Stubbs's Avatar
^^^^^This x 1000^^^^^
My Hudy bearing tool is one of the "non-essential" RC purchases I have zero regrets about making. I've gotten quite a bit of use out of it, as well as replaced bearings for many of my RC buddies. Very nice tool.....
Stubbs is offline
Old 11-21-2015 | 06:17 PM
Hudy is the best here... Don't use cheap tools...
bertrandsv87 is offline
