Like Tree495Likes
JConcepts Thread
Old 09-25-2015 | 07:54 PM
  #8551
Fabulous's Avatar
PW, Any clamping hexes (front and rear) for the SC5M soon? Especially in black!
Fabulous is offline
Old 09-25-2015 | 08:08 PM
  #8552
Wildcat1971's Avatar
Tech Prophet
Are the foams for the 2wd front smoothies a little undersized? When I glues up my tires, the foams do not seem to fill the tire very well..
Wildcat1971 is offline
Old 09-26-2015 | 11:45 AM
  #8553
carcrazy699's Avatar
I was wondering if anyone has tried the rips in the black compound. They are out of green like I use on the rear of the car and was thinking the black or blue. Was thinking of grabbing the golds for indoor clay if they were any good just to try.
Also how are their dirt-tech inserts? I want to try closed foam inserts this time since the open cell foams are breaking down quick
carcrazy699 is offline
Old 09-28-2015 | 10:48 AM
  #8554
PW's Avatar
PW
They are working on something, but no ETA yet.
What I have found is they are to much of a perfect size or slightly big on the wheel, so they don't fit tight on the wheel. This works really well on the treaded tires, but I've actually be running the 2.2" Dirt Techs with the inner ribs/steps cut off for the smoothies .
The black Rip's work well especially if you use the rear white foam cut or the Dirt Techs. They are best for med/low-bite hard packed outdoor tracks that haven't grooved up yet.
PW is offline
Old 09-28-2015 | 03:47 PM
  #8555
problem corrected no fault of the product..
one8updragracer is offline
Old 09-28-2015 | 05:46 PM
  #8556
oPAULo's Avatar
Serration may be worn out on the nut? I wore one out on a 1/10 scale buggy and it kept slightly backing off.
oPAULo is offline
Old 09-29-2015 | 04:06 AM
  #8557
I'm thinking the Same try get the nuts that have the serrated finish and nylon liner
Oh and keep a eye on the serrated edge they wear out
benji lee is offline
Old 09-29-2015 | 06:11 AM
  #8558
PW's Avatar
PW
Originally Posted by one8updragracer
Has anyone had problems with the buggy wheels not holding the hex area tight enough.
Tried some double dees pre mounts indoor last week, tires worked great did exactly what I expected but when I went to take them off one of them was slipping. I had to run a screwdriver through the outdrive to hold the axle so I could get the wheel nut off.
Running A tekno with the closed end wheel nuts. I noticed there is definitely less "meat" in the wheel hex area compared to my AKA and Proline wheels I normally run.
I'm curious if this is 1/8th buggy? We haven't had/sold 1/8th DD's in a very long time, unless it may have been an old clearance item? These would certainly have an older style wheel that was used before the close-ended wheel nuts became popular.
Like you have alluded to, sounds like the close-ended wheel nuts are not allowing the wheel nut to fully engage into the wheel. Our more current wheels shouldn't have this issue and I would recommend using an open-ended wheel nut for those older wheels.
PW is offline
Old 09-30-2015 | 06:39 AM
  #8559
jneezie3000's Avatar
PW, is it possible to do a run of 1/10th stadium Dirt Webs in black compound? I would really appreciate it.
jneezie3000 is offline
Old 09-30-2015 | 07:11 AM
  #8560
PW's Avatar
PW
I don't think there are any plans for this...
Just put some WD40 on some unmounted greens and bag them over night
PW is offline
Old 10-05-2015 | 01:10 PM
  #8561
PW's Avatar
PW
Keep up to date with JConcepts at the 2015 IFMAR Worlds where new products are being covered daily - Click Here
PW is offline
Old 10-05-2015 | 02:47 PM
  #8562
Beau S's Avatar
Default S2 Body
PW, any eta on the S2's availability?
Beau S is offline
Old 10-06-2015 | 06:40 AM
  #8563
PW's Avatar
PW
Within the next few weeks
PW is offline
Old 10-06-2015 | 07:44 AM
  #8564
Congratulations Team Jc
Keith B is offline
Old 10-07-2015 | 06:11 AM
  #8565
skinned's Avatar
any chance on more color choices for 4mm nut #2089-2090?
maybe green or plain aluminum in the future?
thanks
skinned is offline
