Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 05-06-2015 | 04:26 AM
  #691
SagadSetup's Avatar
Originally Posted by rough512
Check your left rear damper, ensure that the piston slides without binding. Drain the oil if you have to. Try switching the rear dampers and see if the oversteering transfers to the left side.
Also, the servo horn and the servo link must be at 90deg to each other otherwise you will have uneven throw. It can be corrected at the radio but I prefer correcting the problem at the root
Servo link is at 90 deg. Throw is even. My dampers are the stock "pogo sticks".
I will look into replacing my dampers with oil filled ones.
SagadSetup is offline
Old 05-15-2015 | 10:10 AM
  #692
Rich Panganiban's Avatar
Quick question for you guys.
What's the best way to "widen" a stock TT-02? In my son's kit, I noticed there was a pair of extra wide plastic wheel hexes. Do you need different stub axles to make those work? When I install them, there is not enough thread to bolt on a wheel.
Thanks!
Rich Panganiban is offline
Old 05-15-2015 | 12:57 PM
  #693
SagadSetup's Avatar
Quick question as well...
Does anybody have a list of parts to convert a regular TT02 to a Type S?
Thanks!
Old 05-15-2015 | 08:09 PM
  #694
Thanks!
List of parts is here ( https://www.tamiyausa.com/product/rc...3#.VVazylVVhBc ) You probably need almost all of it except the lower deck, G, D, B and A parts trees.
I like my Type S so much I wanted to convert my other TT02, but figured it was easier just to buy another kit at $99.
ic-racer is offline
Old 05-16-2015 | 04:42 AM
  #695
SagadSetup's Avatar
Thanks! Very helpful link there. I was also thinking that it would be more cost effective to just go and but a new kit as well.
Old 05-18-2015 | 03:25 PM
  #696
katana's Avatar
I'm just curious, where are you finding type S for sale at that price? I want to do a conversion to Type S suspension however after seeing your post, buying a complete kit may be a better answer to my quest. Thanks.
katana is offline
Old 05-18-2015 | 06:31 PM
  #697
I got my Type-S from RC Mart for $99. It is still listed at that price but it reads "Out of Stock."
A conversion might be cost effective if one had a TRF417 with a broken chassis or something like that. I just think the cost of all the suspension pieces would add up. You need the little spacers, the correct screws, C-hubs, bearings, drive shafts, suspension pins, all the little bits to shim the suspension arms, all the balls for the shocks and more shims, the shocks themselves (somewhat hard to find short ones), balls for the upper arms, the upper arm turnbuckles and cups, F & R shock stays.
I really like my S-type. In terms of balance, it works out better side-to-side than my TB04 Pro.
ic-racer is offline
Old 05-18-2015 | 06:44 PM
  #698
I just saw this "Coming Soon" on the Tamiya site, so S-type kits should still be available.
TT02D S-Type Chassis Kit - Drift Spec #47301
Looks like TT02 S-Type with drift tires and motor heat sink.
ic-racer is offline
Old 05-18-2015 | 07:56 PM
  #699
SagadSetup's Avatar
According to Qatmix this will be the highest spec TT02 once released.
Here's the link. Just scroll down. http://www.thercracer.com/2015/05/al...ouka-2015.html
I am looking forward to having this kit.
Old 05-18-2015 | 11:41 PM
  #700
rough512's Avatar
I did my DIY conversion to S. It is not complete though. I'm definitely buying that drift S-type when it reaches the LHS.
rough512 is offline
Old 05-19-2015 | 04:57 PM
  #701
SagadSetup's Avatar
I am definitely getting at TT02 S. I saw somewhere that there will be a provision for droop screws.
Old 05-19-2015 | 06:24 PM
  #702
Just to continue with conversion discussions. Those of you with Type-S know this but those that don't have the car, you can see the 'special' pieces needed for the conversion. There are not that many as seen in this picture. The complexity is that you then need the complete suspension and drives from a 417, 418, 419, TB04 Pro or similar.
ic-racer is offline
Old 05-19-2015 | 06:34 PM
  #703
SagadSetup's Avatar
I guess it would be more cost effective to buy the Type S kit itself.
Old 05-19-2015 | 07:02 PM
  #704
rough512's Avatar
Plus the shock towers and the suspension spacers/mounts are not really available separately.
rough512 is offline
Old 05-19-2015 | 07:20 PM
  #705
SagadSetup's Avatar
Thanks for the info.
