3 lipos for 1 car? 2 is more than enough. If you're running modified the Reedy #738 wolf pack is more than enough. If you're running stock... If probably get the more expensive higher C packs.
Original plan was to run stock but I could run mod.
In stock at AE...free shipping as well
http://www.teamassociated.com/parts/details/90000
Four seems to be the best though. I currently have three and can only two at once on my charger. I get backed up often and I charge at a conservative 8 amps. Running mod class.So I often have to wait for batteries.
Is anyone running modified racing with 25c lipo packs? Hows the speed? I have a 3800kv mmp setup from my sct that im thinking about using instead of 17.5 spec.
http://www.hobbyking.com/hobbyking/s...dProduct=28647
or
http://www.hobbyking.com/hobbyking/s...h=turnigy 4200
I have been thinking on trying a Vant . http://thebarnfloor.com/catalog/prod...8#.VTFEgWF0yos
I charge at 6 amps 2 packs per car... I'm never waiting on a pack. Maybe if I practice on one pack for like 15 min. Once racing starts I only use like 1800mah at most.
Charge at a higher rate. I routinely charge at 16amp (about 4c)with no issues.
If you are looking for the 45$ mark you can get the Turnigy
or
or
I have one of their packs, and I cannot tell the difference, It cycles on my gfx only slightly less average voltage and my team scream pack.
