Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree141Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 01-21-2015, 03:12 PM
  #17461
hi im building my shocks put oil in and blead them one shock shaft pulls itself all the way up and the other doesnt move much. please help
DIRT DIGGER is offline
Old 01-21-2015, 03:24 PM
  #17462
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Just pump the shaft in and out a few times (what she said...). It's an emulsion shock so you need to mix the air with the oil evenly. It will balance out.
Jmuck69 is offline
Old 01-21-2015, 03:33 PM
  #17463
thank u. is it suppose to suck back up when u pull it out?
Old 01-21-2015, 06:44 PM
  #17464
sanderson373's Avatar
Originally Posted by iScream
Thanks, Scott. I've got a 17.5 in it right now cause I thought that was gonna be required. I decided on Saturday to redo the setups on both buggies and didn't have the B5 ready by the time I got there Sunday. So I ended up only running the D413.
I'm going to leave the 17.5 in there for this Sunday and see how I like it but want to be prepared with a mod motor depending on how things sort out with classes as we get going on the new track.
-Chris
Well I'm not gonna tell u what to fun but 17.5 is whatevery body is running because its plenty of fast and more controllable plus the track ain't that big so you can't open it up with the 8.5 like you can with the 17.5
sanderson373 is offline
Old 01-22-2015, 12:37 AM
  #17465
HYPERformance06's Avatar
Is it bad I'm running a tamiya part on my car? Could it be curse? Doesn't seem like it since I usually tq
Attached Thumbnails Team Associated RC10 B5m Mid-Motor & Rear Motor Thread-image.jpg
HYPERformance06 is offline
Old 01-22-2015, 12:39 AM
  #17466
Cursed? Tamiya parts lol
Old 01-22-2015, 12:44 AM
  #17467
Has anyone ever made these homemade wing mounts? The spacers are the old axle spacers off the b4 before they went to hex. Went behind the hub pin. Then you cut of some of the post and drill a hole. I cut just enough so the wing still sits onto the posts. I did this to my b4 as well. All of the screw wing mounts I have seen are all aluminum. I don't think I can trust aluminum mounted to my shock tower. Because when you flip over, the front shock tower and the rear wing take all the impact, and being the wing mounts are mounted in the middle of the shock tower I could see it snapping the tower. Rather have the mounts be flexible
Old 01-22-2015, 03:29 AM
  #17468
Trader Rating: 18 (100%+)
Did mine the same way,only I used wing washers from 8th scale.wings last longer now without those little clips to tear through the wing.
xxxntwv is offline
Old 01-22-2015, 06:08 AM
  #17469
Jmuck69's Avatar
It will initially from the vacuum created when bleeding but after pumping the shaft quickly in and out a few times it will equalize and be fine.
Jmuck69 is offline
Old 01-22-2015, 07:00 AM
  #17470
couldnt agree more. the wing stay solid until its time to replace it. never had one where it would rattle on the mounts like they did being mounted with clips
  #17471
Cridd's Avatar
Trader Rating: 16 (100%+)
Look cool
Cridd is offline
Old 01-22-2015, 07:34 AM
  #17472
timannnn6's Avatar
Trader Rating: 140 (100%+)
Just a heads up....SMC's got most batts in stock including shortys.
http://www.smc-racing.net/index.php?...ory&path=67_97
timannnn6 is offline
Old 01-22-2015, 07:40 AM
  #17473
Originally Posted by Cridd
Look cool
yea i bought them a month ago. couldn't find anything for the b5m because no one carried them until a few weeks ago. now avid and other make them but they are all black and are just plain looking no cutouts at all
Old 01-22-2015, 07:46 AM
  #17474
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
In general Blue is my favorite color. But for RC I prefer it to be blacked for the most part. Also, the Avid's are keyed to prevent popping off.
Wildcat1971 is offline
Old 01-22-2015, 08:00 AM
  #17475
ive never had a spring perch rip off. it has to be slid up and then pushed over for that to happen.
