parallel board/harness charging help, please... >
Old 01-13-2015 | 05:45 PM
Default parallel board/harness charging help, please...
Hey all,
I am having a hell of a time trying to figure out how to make this work for me. I will give you the scenario.
dual output 10A / 100-200 Watt charger w/ a 47A 575W juicebox PS.
I am trying to figure out how to charge 1 X 2800 mah 2s protek tx lipo batt and 3 X 2000 mah 2s protek rx lipo batt on each output. This would be a 8.8A 1c, and consume approx. 65watts per channel. 2s4p 8800mah batts.
The batts have XH balance connectors, and JR charge connectors.
I have looked for parallel boards that have the Jr female charge ports on the board, but haven't found anything. I also looked into making my own harnesses, but run into amp and gauge wire size problems. for a 8.8+ amp load, you need to run,at least, 18 gauge wire.
I thought about making XT-60 to Jr female leads, but think 18 gauge is too big for the Jr's and too small for the XT-60's? I looked into also purchasing harnesses, but all the Jr female connectors have 22 gauge wire, at the largest.
Could someone help me figure out how to get either a harness built up, or a board that will do what i want?
unlvjeffro is offline
Old 01-14-2015 | 10:53 AM
no one could help a brother out huh???
Old 01-14-2015 | 11:00 AM
DRTMI's Avatar
Super Moderator
What is it for? Those type of connectors are pretty small.
DRTMI is offline
Old 01-14-2015 | 12:58 PM
JimmyG's Avatar
For that gauge wire, you would need to make adapters. This is as close as I could get. Just need to make adapters.
http://www.progressiverc.com/paralle...st-xh-jst.html
JimmyG is offline
Old 01-14-2015 | 03:40 PM
I'd try contacting Progressive RC. I don't see what you need listed, but they make a wide variety and have great service, might be able to set you up. In general they have both parallel board and harness options.
Another possible source is Buddy RC.
Dave H is offline
Old 01-15-2015 | 05:56 PM
Well, thanks all.
I was thinking about these items... Will this work?
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Would the JST plugs be easier to solder with the 22 gauge wire? Are the XT-60 plugs not able to take that small of wire effectively? I could make extra long stripped ends and fold them in half if I need to.
Does anyone know if I could use 18 gauge wire on JR female connections, or is it too big, like i am suspecting it is?
Would 8.8A be too much for 22 gauge wire?
