HW SCT-PRO with 4k pro4 input
I have the sct pro paired with the tekin pro 4 hd, lipo 2s 5k 60c 130 burst. Sc10 4x4. Vts and clickers locked. I do run it with the sensor no timing so smooth, on a high bite technical indoor carpet track with jumps. A bunch of us run for fun on non race days and anything goes. This setup keeps my motor around 125 deg after 15-20 min hard running.
It doesn't feel much faster than with the mmp but the servo seems better off. I thought this motor would crank. Don't get me wrong it pulls but just not what I thought. My 5700kv 2wd Sc10 is all over it and will pull the wheels up on occasion. I want to keep my temps and run time. I'm looking for more top end but want to keep the torque for the tight turns. Any suggestions on motor choice or esc with boost. Almost everyone is running tekin rx8 gen2 combos and on the straight it's so close need just a nudge to pull away. Looking for suggestions.
Your radio's throttle epa was set at 100% when you calibrated to the esc? If so, then pull full throttle and turn the epa up from 100% to 150% and see what happens. You can do it on a stand.
