m12 question
Old 10-27-2014 | 06:17 PM
Default m12 question
how do you setup steer dual rate over ride on a button or a switch... im lost...thanks!!!
ACEDEAN is offline
Old 11-02-2014 | 10:16 PM
cant be done?
ACEDEAN is offline
Old 11-02-2014 | 11:48 PM
Salkin's Avatar
There's a dedicated thread for the M12. Find it and use the search option.
Salkin is offline
Old 11-05-2014 | 04:41 PM
thank you but i been here 9 years longer than you, i know where the search button is, was trying to find the answer asap....sorry to tweak your panties
ACEDEAN is offline
Old 11-05-2014 | 05:35 PM
If you need a quick answer then using the existing thread which has some 1,600+ posts and 238,000+ views, and many owners subscribed, might well be the better approach. Plus it might help someone else out looking for the same info.
Not criticizing, only trying to help. I see this all the time, new threads go begging for input, while more active threads frequently get responses fairly quickly. No guarantees though, so I will leave this thread open for now.
Dave H is offline
Old 11-06-2014 | 02:03 AM
Salkin's Avatar
I don't mind getting my panties tweaked....as long as it is not my touring car.
Salkin is offline
Old 11-06-2014 | 07:19 PM
By default steering dual rate is on trim 3.
If you want change that you need to go into the "system" menu and select "assign". As far as I can tell you can't assign steering dual rate to any and everything.
From with in that menu, use the scroll wheel to select trim, dial, switch or lever and scroll through that menu and see if steering dual rate is an option. It may not be.
I found it for "lever", "trim" and "dial", but not for "switch".
My ST-RR EVO is offline
