1/18 ECX Ruckus w/ Castle Creations Mamba Micro Brushless System
I own a Traxxas Slash now and I want to get into mini scale. I just bought a 1/18 ECX Ruckus and I want to put a Castle Creations Mamba Micro Brushless System into this car. This is my first project car and I would like some guidance. Any advice, recommendations, or tips would be appreciated.
My Questions..
Will this even work with a Castle Creations Mamba Micro Brushless System in a 1/18 ECX ruckus?
Will the motor fit in the car?
Is this a smart thing to do?
Will I need to upgrade anything else because I put a high power motor in this car?
My Questions..
The better choice for the ECX Ruckus would be a brushless system from the Losi Mini 8ight or a brushless motor called the "Ammo" from Great Planes paired with a HobbyKing 60amp Mini ESC. I believe you can get a 3900kv motor to replace that 370-380 size motor. Part no. for the Ammo motor is GPMG5200 from Great Planes. Losi also has a Lipo option part #LOSB9835 for 2s or LOSB9836 for 3s output from the Losi site.
the mamba micro system works well for the mini-t platform and the associated rc18 platform but they are quite small compared to the 1/18 Ruckus which is about the same size as the Dromida SCT 1/18. Dromida has a brushless kit that includes:
FEATURES: Upgrades stock 370 size brushed motor supplied with Dromida 1/18
scale vehicles
All components required for brushless operation
INCLUDES: 25A Brushless ESC, DIDM1002
12T Pinion for the MT4.18, DIDC1032
13T Pinion for the BX4.18, and SC4.18, DIDC1115
5300kV Brushless Motor, DIDC1128
Brushless Conversion Receiver, DIDL1000
Brushless Bellcrank Set, DIDC1130
Brushless Steering Linkage, DIDC1129
Brushless Servo Mount, DIDC1131
2.5x6mm Socket Head Screws, DIDC1132
Hope this helps your speed cravings. So is this a smart thing to do? Well hind site is always better then foresight. If you got the money go for it.
scale vehicles
From what I hear, If you have a need for mini speed, you'll want almost anything else other then the newer ECX 18th scale, since they have no real aftermarket parts support. you'll just be buying and breaking the same parts over and over. I think an rc18t would be a better choice for you if you want speed runs out of a mini. Maybe even a Mini-T if you're crazy like me (haven't finished mine yet, kinda hard to find the original plastic main gear cover for some reason. I might think about buying a loaner car until I decide to go full mod Franken-T.
