Go Back  R/C Tech Forums > General Forums > Rookie Zone
exo Terra buggy reception issues please help >
Old 10-19-2014 | 04:46 PM
Questions?? exo Terra buggy reception issues please help
So.. It goes 10' and stops, simply stated. I installed new servo gears two days ago and car has worked fine. It appears to me that it has something to do with interference because it works correctly within 10ft. I bought this exo used about a week ago. It has been working great until today. It's the 2.4 ghz receiver ax3, has the vanguard AE3 ESC. Any help would be appreciated. I'm new here and to Rc... So PLEASE FORGIVE ME for starting a new thread.
Kevin_ExoTerra is offline
Old 10-19-2014 | 09:39 PM
metalnut's Avatar
So... if you turn it on and drive 10 feet, what happens? Does it glitch at all, or does it just die?
What if you walk 2 feet behind it... can you drive it for an extended period of time that way? Is there any correlation between it stopping and the speed at which you were driving, the length of time you were driving, or the bumpiness of the surface? Or is it literally only distance?
It could be that the antenna on the receiver is damaged (not sure if it's external or not), or maybe the transmitter is faulty. I'd say call up Axial and see if they can help you diagnose it.
metalnut is offline
Old 10-20-2014 | 09:36 AM
MarkA's Avatar
I would start by re-doing the bind procedure but then clarifying metal's questions could help clear up the issue.
MarkA is offline
