The Speed Passion Thread >
Like Tree57Likes
Old 09-18-2014 | 08:12 AM
  #12706
Default Please help
I have a GT V2.0. I transferred the esc from one car to another and It won't calibrate. The red light keeps blinking. Sorry if its been asked before
fx35rc is offline
Old 09-18-2014 | 11:58 PM
  #12707
Electr0n's Avatar
If you are using a different transmitter, reverse the throttle channel and try again.
Andre
Electr0n is offline
Old 09-19-2014 | 10:41 AM
  #12708
Andre
Thx Andre. Unfortunately i am using a same transmitter. I'll give speedpassion a call
fx35rc is offline
Old 09-20-2014 | 07:34 AM
  #12709
asw7576's Avatar
Electr0n ,
Hi ... i already update firmware for my ESC reventon pro 1.1 ..... it can do reverse now ... hahaha.
asw7576 is offline
Old 09-22-2014 | 08:43 AM
  #12710
Hi all,
Today was first time I used my combo Reventon S with 3.0s sensorless motor purchased 2 weeks ago.
After 3 laps, the car stopped and a white smoke was coming out from the car. After reached the car on the track, i saw the white smoke coming from the ESC.
The ESC was completely burned on the connector side!!!!
can someone helm with RMA in europe?
Zulianino is offline
Old 09-22-2014 | 11:33 PM
  #12711
Will the Competition V4 motors be available in "stock" winds?
HawkSpeed is offline
Old 09-23-2014 | 03:06 PM
  #12712
SamuraiJack's Avatar
What gauge wire comes with the reventon pro?
SamuraiJack is offline
Old 10-01-2014 | 05:17 PM
  #12713
Mr_RCGuy's Avatar
does anyone know if there are standard hubs that will fit over the rear axle to replace the hex hubs of the LM-1?
Mr_RCGuy is offline
Old 10-05-2014 | 08:55 AM
  #12714
BRAND NEW Speed Passion MMM 17.5R , less then 5 minutes of run time, conservatively geared. I would say this is a manufactures defect??? I've never had a brushless motor do this, let alone a brand new one.
Jeepy2013 is offline
Old 10-05-2014 | 09:53 AM
  #12715
Wow. I have a brand new one laying around. You could have it. PM me.
kwiksi is offline
Old 10-05-2014 | 11:48 AM
  #12716
After the modified motors are released then the "stock"winds are supposed to come.
Unless there's an aftermarket company making something now I don't believe there is one.
Nexus is offline
Old 10-05-2014 | 12:01 PM
  #12717
Do y'all have plans on a 8th esc I'm running reventon pros in my 10th truck and am happy with them but with no offering for 8th I'm going to have to go to a different brand and will probably switch 10th over to for simplicity. Hate to do that but the easier my life and setup is the easier it is for me to win.
riley1131 is offline
Old 10-06-2014 | 02:36 AM
  #12718
Hi there, got problem w/ heat.
I have a Speed Passion 3.5T MMM motor with Reventon Pro 1.1 install in my touring. FDR = 8.9 Running with blinky mode (stock 0 - zero timing firmware). Extra Fan attached.
I get an overheat issue only running maybe 2 - 3 minutes. Symptoms : powerful at the beginning then when it reach the thermal cutoff it loses the power (still can move but no power).
Then I let it cool for a while and try again but same result.
Question :
1. Is my FDR is to low , I meant do i have to change to a smaller pinion ?
2. Is it correct to use this motor in zero timing ?
Any suggestion on what may be the problem. ? Please help me on this. Thank you.
jhs3373 is offline
Old 10-07-2014 | 06:32 AM
  #12719
Electr0n's Avatar
What kind of track are you running on ?
For a long Fast track then your FDR should be right ( around 9.0 ).
Also i never used stock 0 firmware but always stock 1 when driving a modified motor. (normally this should not be a problem)
Andre
Electr0n is offline
Old 10-07-2014 | 11:01 PM
  #12720
Andre
It is on asphalt track w/ some turning and 1 straight line (around 80 - 100 feet long) . I thought that because this is a 3.5T motor (highest KV motor) than i just using the stock 0 and no need any turbo feature. Do you think this MMM motor should use mod firmware ?
jhs3373 is offline
