Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree141Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 08-17-2014, 05:33 PM
  #13321
shannow's Avatar
Okay I just bought the B5m I'll give a feedback here of how it compares to the Kf and 22 2.0 especially on multi-surface in Europe .
shannow is offline
Old 08-17-2014, 05:41 PM
  #13322
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Originally Posted by jccj816
Are these the correct turnbuckles for the B5 ?
http://www.amain.com/JConcepts-B4-Ge...-Set-6/p254966
Yup!
Jmuck69 is offline
Old 08-17-2014, 05:42 PM
  #13323
Wild Cherry's Avatar
Originally Posted by TOO-TALL
Where do you buy the thin sheets to fit under the battery?
Trcr purchase some from a roofing supply next door.
1/24 in.
Google lead sheet , a company there sells as well.
Wild Cherry is offline
Old 08-17-2014, 05:48 PM
  #13324
Jmuck69's Avatar
Yup!
Jmuck69 is offline
Old 08-17-2014, 08:27 PM
  #13325
thecman26's Avatar
Trader Rating: 112 (100%+)
I found some at Hobbytown, KS Metals sells sheets of different sizes and thicknesses.
http://ksmetals.com/30.html
thecman26 is offline
Old 08-17-2014, 09:01 PM
  #13326
Trader Rating: 166 (100%+)
Originally Posted by mxracer458
im switching my car back to rm from mm, whats everyone prefer for a med to higher bite tracks…gull wing fronts or straight arms?
Like mine the way it is with the stock arms. Don't see a need to change at all.
jpcopeland1 is offline
Old 08-17-2014, 09:07 PM
  #13327
BRSracing's Avatar
Trader Rating: 67 (100%+)
Originally Posted by jpcopeland1
Chalk up another win with B5 with basically box stock setup over B5M. LRH, loamy wet clay switched cars after B5M was swapping rest ends. Moved to B5 with typos, 2X1.6 flat pistons 32.5/30. Stuck to the track, beat out fast mid-motor guys who were pushing all over the place no matter what mods, or clay setups posted anywhere.
What springs are you using?
BRSracing is offline
Old 08-17-2014, 09:19 PM
  #13328
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
I am giving the MM experiment a break. I got my car good, but it is just not what I want on the bumps and jumps. And for 17.5 the lighter and more plush RM car feel overall most consistent. On, the flowing parts of the track the MM was nice. But on timed jump sections or short run up jumps it never felt "right". The Rm turns like a pig, but at least I always know what it is going to do. The MM liked to "surprise" me.
Wildcat1971 is offline
Old 08-17-2014, 09:21 PM
  #13329
Tech Prophet
I am running the kit arms with green fronts and white rears for high bite. If you have really high bite, you might want to use the 2.5 rear toe instead of the 3.0. 32.5/30 oils with 1.6 pistons front and rear is what I plan to use.
Old 08-17-2014, 10:43 PM
  #13330
Using mid tower & flat front arm with inside hole, the
shocks are at the same angle as using rear motor tower middle hole.
Difference is the shocks are lower a couple mm with mid tower & inside tower hole.
Lower makes for lower CG on front .
Makes for smoother steering.
Sorry never seen that graph.
I just thought maybe you were interested.
Thanks, that was what I was after! So inside holes on both mm tower and flat arm then?
Pellefa is offline
Old 08-18-2014, 12:58 AM
  #13331
For those having ball cup binding issues. Go grab some silicone spray from NAPA. It comes in a blue can And it is a NAPA house brand I believe. Spray into the ball cups and thread them in. I used this when I built my last kit And the turnbuckles adjust like butter.
Dagolf is offline
Old 08-18-2014, 06:50 AM
  #13332
Pellfefa
Only for mid tower & flat arms.
Use inside hole on tower & outside hole on arm.
Old 08-18-2014, 06:57 AM
  #13333
Sounds way better then reaming ...
Which Ti rod are you using ?
Old 08-18-2014, 08:13 AM
  #13334
i just built my b5 (sorta my 1st car) last weekend and was finally able to get it running this past weekend and i had a few questions about replacement parts.
typically is this the order of 'better' parts?
brass > aluminum > plastic ? i use the term 'better' loosely, obviously. i gather that bronze is heavier on the car than the aluminum but is it more durable? i see i already need to replace my front hinge pin brace, haha.
aside from that, i actually cracked my reedy square battery pack:
is that normal? this was only on my 4th run so that sorta sucks. is that caused by having the battery too tight?
it's weird 'cause nothing else truly broke. bent a turnbuckle a little bit, cracked the battery, and cracked the front hinge pin. was plenty of fun though!
alphaclass16 is offline
Old 08-18-2014, 08:16 AM
  #13335
Tech Prophet
Contact AE/Reedy on the battery. Also, there is nothing wrong with the plastic parts on the car. Alum hexes in the rear are nice, and the alum rear suspension holders make it easier to change Anti Squat and toe.
