The Speed Passion Thread >
Like Tree57Likes
Old 06-16-2014 | 12:18 PM
  #12631
Default Thanks for the reply "dan_vector"
I tried 3 sensor wires, all of them tested with other ESCs. Also tested them for continuity with a multimeter.
I re-did the transmitter calibration several times (at least 10 times), always the same result.
I asked here, because I was ran out of ideas to test.
Thanks again.
kikerumbo is offline
Old 06-22-2014 | 07:49 PM
  #12632
Pittster's Avatar
Gday all,
Quick question.
Has anyone experienced a Reventon Pro cutting out i.e. turning off landing jumps??
I tried a new Sensor wire, checked connection and solder, with no success.
Im going to resolder the terminals check the capacitor, pull the lower housing off and give it a good clean.
Has anyone else experienced this and found a solution.
I had it occur once per race, usually from jumping.
Pittster is offline
  #12633
Pittster's Avatar
Pittster is offline
Old 06-24-2014 | 08:22 AM
  #12634
dvaid852456's Avatar
Originally Posted by Pittster
Gday all,
Quick question.
Sounds like a dry joint somewhere. I know some early ESC's had soldering issues from previous posts. Is it an orginal Reventon Pro, was it purchased near release?
If it still does it after checking all the external solder joints and receiver connections it maybe worth eyeing up the mainboard soldering or asking SP if they are able to exchange it.
dvaid852456 is offline
Old 06-24-2014 | 08:40 AM
  #12635
Originally Posted by Rc-007
hey...im trying to update my SP GT 2.0 pro to blinky mode software(HW 508 no timing)...but when i try to update through usb link it says this "The current version (V3.0_120428STOCK) can not be updated to the version (V3_508_No Timing)!" Can someone help me? I'm running the esc with a 17.5 and it needs to be blinky...any suggestions?
using the HW 2 in 1 pro LCD box FW is HW v1.08_120504
esc fw is V3.0_120428STOCK
I would start by having the SP software on your PC and FW on the card. Are you using the Hobbywing card for other HW ESCs also?
Gday all,
Quick question.
Sounds like a bad solder connection maybe. Did you check if your capacitor came loose and or what servo are you running? Some drivers, depending on their electronics, were running external BECs due to brown outs.
Nexus is offline
Old 06-25-2014 | 04:03 PM
  #12636
Default version 4 motors
Any update on the spec v4 17.5 and13.5 release dates?
astgerma52sp is offline
Old 06-25-2014 | 07:19 PM
  #12637
No specific date. The V4 modified motors will mostly likely be for sale first.
Nexus is offline
Old 06-25-2014 | 07:49 PM
  #12638
Pittster's Avatar
Yeah im going to examine the lower PCB in the ESC clean it resolder my main connections check capacitor and add a novak glitch buster I have.
I run a Savox 1258 but I have never had issues with brown outs since going away from spektrum receivers and now using HobbyKing Orange Rx ones.
Thanks for the suggestions hopefully it fixes it
Pittster is offline
Old 06-29-2014 | 03:10 PM
  #12639
JoeyE's Avatar
I have the Reventon Pro 1.1 EX. Am I going to need to install a battery pack on my receiver running 1S 1/12 scale? Everything seems to work ok without one at the moment.
JoeyE is offline
Old 06-29-2014 | 06:04 PM
  #12640
RacinJ's Avatar
The EX version of the Reventon Pro 1.1 is designed for 1 cell. It has a built in booster for the radio. Just update the firmware to the latest version and run it. It works fantastic in 1/12th scale.
RacinJ is offline
Old 06-29-2014 | 07:48 PM
  #12641
JoeyE's Avatar
Cool, thanks~!
JoeyE is offline
Old 06-30-2014 | 05:39 AM
  #12642
LOSI123's Avatar
Can one set say drag brake to a "Custom" value in the reventon R ?
I can not figure out how or if its posible
Im running the Mod software that came on it from the factory
LOSI123 is offline
Old 06-30-2014 | 07:31 AM
  #12643
Ranger411's Avatar
Anyone know a phone number to call Speed Power RC in Chicago(SP US warehouse)? I sent in a broken Reventon Pro. Was promised a replacement via the chat on the site, but that was a week ago. Emails go responded to.
Ranger411 is offline
Old 06-30-2014 | 01:15 PM
  #12644
You do not need to. As stated the EX was designed with 1s racing in mind. It will work fine without one in your 1/12. Many use it in 1/10 also because they like the black color
PM me the details of your RMA and I will look into it.
Nexus is offline
Old 06-30-2014 | 01:17 PM
  #12645
Default Tuning Haus wins
Chris Vogan won both USGT and USVTA using Speed Passion ESCs at the 2014 Tuning Huas Party!
USGT Car
-Hot Bodies TCXX with Arrowmax Aluminum Chassis
-Speed Passion Reventon Pro EX ESC
VTA Car
-Hot Bodies TCXX
-Speed Passion Reventon Stock Club Race ESC
Nexus is offline
