Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 05-03-2014 | 01:59 AM
  #316
No, I have no movement between the axles and the bearings, the shimming will help.
remember though, a little bit of movement is fine, a car with no slop is usually binding or shows up any other minor imperfection in the rest of the components.
Qatmix is offline
Old 05-04-2014 | 01:53 PM
  #317
Default Has anybody purchased the TT-02D?
It comes without a body but that's okay since I'm not totally happy with the rally based body choices in kit form.
djfourmoney is offline
Old 05-04-2014 | 03:40 PM
  #318
Djchow85's Avatar
Has anyone upgraded their front knuckles to aluminium ones? After about 25 or so cartwheels/front flips, face plants of my tt02 I've finally busted my left front knuckle... i've opted to order the standard parts as they're cheap.. but thinking now maybe I should've gone aluminium ..
If so has anyone had issues of the aluminium knuckles bending under stress from bashing etc?
Djchow85 is offline
Old 05-04-2014 | 11:59 PM
  #319
Currently I have been using the reenforced plastic ones. These are on the a parts sprue for the TT02D you can buy the A sprue separately. It's well worth it as you get a lot of the key components (steering, towers and hubs) all in the harder plastic.
I have also bought the aluminium front parts from jaz hobby on eBay. They seem good value but they are in my spares bundle atm as I prefers plastic where possible.
If rallying then I would have no problem swapping the out to these parts.
Qatmix is offline
  #320
If rallying then I would have no problem swapping the out to the alum hubs.
Qatmix is offline
Old 05-06-2014 | 04:47 AM
  #321
Djchow85's Avatar
Wouldn't have thought they'd change the plastic just for d spec!
Djchow85 is offline
Old 05-06-2014 | 06:19 AM
  #322
Only the A parts, they are very good.
Qatmix is offline
Old 05-06-2014 | 03:47 PM
  #323
Djchow85's Avatar
yeah i got the jaz ones. They were the cheapest and included the collars etc which the others don't!
I'm already eyeing a buggy for xmas... good learning experience since the tt-02 is my first!
Djchow85 is offline
Old 05-14-2014 | 09:20 AM
  #324
Smile's Avatar
Do you have a part number for those by any chance?
Smile is offline
Old 05-15-2014 | 01:47 AM
  #325
Part number is 19000614
Saying that I have just broken one of the front hubs (Although I whacked a board at full tilt)
Basically it comes with harder plastic versions of the towers, upper bulkheads, Front and rear hubs (and spacers) and it also comes with the steering arms. So most of the key parts you want to be stiffer are there.
You will still need to file down the limiters on the front uprights if you want a lot of lock though.
I am now going to try the Jaz hobby hubs to see how they work.
Qatmix is offline
Old 05-17-2014 | 06:09 AM
  #326
Smile's Avatar
Damn, the reinforced a-parts has an 8 digit part number, which means they're not readily available, and is by order. Why can't Tamiya make this an official TT02 hop-up?
By the way, if I ordered one, would it come with two trees or only one?
Smile is offline
Old 05-17-2014 | 12:36 PM
  #327
Mine came with 2 trees and the wheel hex's on a seperate sprue with a silver metallic coating.
Qatmix is offline
Old 05-18-2014 | 03:09 AM
  #328
Djchow85's Avatar
One thing I don't like about the jaz set are the screws. I'm not sure if it's possible to tighten the hex screw at the top as I may limit turning. Took it out to the track and the screw and collar went missing
I have a feeling the stock parts may be better as the screws stay quite tight in the plastic knuckle
Djchow85 is offline
Old 05-22-2014 | 02:29 PM
  #329
Today i looked at the chassis to loose some weight, did some things to remove some material but not much.
The car is fully equiped (except my transponder) and i got it down to 1180gr.
It allmost weights 200 gr less then my other standard TT-02.
addicted2blue is offline
Old 05-22-2014 | 03:12 PM
  #330
Pics please
Qatmix is offline
