Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree141Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 05-16-2014, 10:39 AM
  #9976
Trader Rating: 24 (96%+)
Originally Posted by suby723
Using b5r rear arms flipped DONT move the arms 1 to 2mm forward. Its .75mm forward to be exact.
Sorry, I wasn't exactly sure, I'll fix my post
dezertranger96 is offline
Old 05-16-2014, 11:02 AM
  #9977
gticlay's Avatar
Trader Rating: 14 (100%+)
It's pretty well established that the RM arm mod is 2mm forward.
Attached Thumbnails Team Associated RC10 B5m Mid-Motor & Rear Motor Thread-2mm.jpg
gticlay is offline
Old 05-16-2014, 11:55 AM
  #9978
Mason's Avatar
Originally Posted by davidbarton87
Guys over in the rear motor thread have been talking about raising the front hubs, figured I would share over here as well. Used a technique that Luke Smith used on his Centro to raise the hub 1mm. If you were looking for a basically free way to try out the raised hub here is the way to do it. If you dont like it then move the 1mm spacer to the top and you have the original hub position.
I'm not seeing the modification done. Are they grinding on the steering arm, changing/grinding out shoulder bushings or ??? I was under the impression that new shoulder bushings with various thicknesses on the shoulders would be coming out so you could adjust this.
Mason is offline
Old 05-16-2014, 12:03 PM
  #9979
Mason's Avatar
offset bushings.. where the hell was the 8th AE spamletter this week about these being released??
http://www.teamassociated.com/parts/details/91403/
Mason is offline
Old 05-16-2014, 12:16 PM
  #9980
markt311's Avatar
Trader Rating: 34 (100%+)
Cause they were in stock for the last 1 1/2 months
markt311 is offline
Old 05-16-2014, 12:27 PM
  #9981
Mason's Avatar
Does anyone else have other cooling mods they've done?
One's i'm currently aware of are the motor band mounted fan, waterfall mod/mount.
Anyone doing scoops or vent holes on the body? gator teething or shimming the gear cover?
My motors currently are running okay. I've been thinking about helping that out a bit in the future but I'm currently mired with a heck of a time keeping my tekin rs cool. It has the latest software (i believe) and I'm in blinky mode with some wimpy mod motors (10.5/13.5). We use a lot of heavy brakes on the currently layout and I'm sure some of that is the problem for the regular RS. Unfortunately with the 10.5 (same elec setup as my previous B4 and never had an issue like this) i've been between 23/81 and 27/81 with very little speedo change (170F!) so I've dropped to a 13.5 thinking maybe something is wrong with the motor and it has not gone down much. Can't drop the gear on it much more either as the 17.5s nearly walk me down the front straight now! Transmission seems okay but I guess I need to take it apart and verify.
So let's see some of your ideas!
Mason is offline
Old 05-16-2014, 03:23 PM
  #9982
pullstarter's Avatar
Hey Guys,
Is anyone having issues when building their shocks that the top o-ring that sits under the top cap is bulging when you tighten down the shock cap? I've managed to get 2 together by poking the damn thing back in at the same time as tightening the cap down but there must be a better way? It makes building consistent hardness shocks difficult also Any tips appreciated.
pullstarter is offline
Old 05-16-2014, 03:47 PM
  #9983
Originally Posted by abailey21
I was told by Nick at Associated by shimming it up (thick brass on bottom) you will get more on-power steering, thick on top more off-power steering
i may have to try that then. that is my only problem with the buggy right now, not enough on power steering.
bbrace3m is offline
Old 05-16-2014, 03:53 PM
  #9984
Originally Posted by pullstarter
Hey Guys,
I just built mine this week and didn't have any issues.
Maybe mixed them up with the ones that go in the shock collars or got something on them that would cause them to swell?
Hacksback is offline
Old 05-16-2014, 04:00 PM
  #9985
Good point I'll try swapping them over, definitely no contamination on the o-rings themselves though, cheers.
Old 05-16-2014, 04:34 PM
  #9986
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
run without a body....:-) I would run a lower turn motor that will run cooler. MM cars always run warmer. I gained 30 deg trying to run MM.
Wildcat1971 is offline
Old 05-16-2014, 05:28 PM
  #9987
vito's Avatar
iam up to the diff now in the bilud
vito is offline
Old 05-16-2014, 05:44 PM
  #9988
I drove a car with long front and rear links this weekend and it turned on a dime while on power. It also had the +2 trailing insert in also. But the suspension really leaned in the corners making the car turn hard. I run short links and I am undecided which I like better. I plani to do more testing indoors on medium bite since i have 2 b5. Run them both back to back with the same tires. One with shorter links and one with longer and +2 inserts. The car was also using the 30 deg kick
Longer links should be less chassis roll. Maybe he had a softer shock set up then you are used to.
bambambennett is offline
Old 05-16-2014, 05:45 PM
  #9989
Sorry guys, stupid question time, which one of the spring cups is the 5mm offset?
Old 05-16-2014, 05:51 PM
  #9990
trixter91's Avatar
I am running 25 degree kick stock front camber links and 2 inserts and I need more steering so if i shorten my front camber links it will react faster will it do anything negative.
trixter91 is offline
