Tires off rims
Old 05-16-2014, 05:05 AM
Default Tires off rims
Does anyone know a way to take a tire of a rim. I have a bunch of good tires I want to use on a different car than the rim is for
wragusa is offline
Old 05-16-2014, 05:08 AM
theproffesor's Avatar
Trader Rating: 66 (100%+)
Let them sit in acetone over night. That should do it.
theproffesor is offline
Old 05-16-2014, 05:40 AM
Turn your oven on 350 once hot, put tires in for 10 minutes. Turn off oven and let the tires cool for 15 minute in the oven. White rims will yellow the foams will be shot but the rubber will be good and the glue will be easy to pull off with fingers. The acetone trick works but i put a cup of acetone in a bucket then the tires around the cup and cover the bucket and just the fumes will remove the glue. Acetone gives me a headache for like a week. That stuff is superbad for you.
sobiski racer is offline
Old 05-16-2014, 06:48 AM
oeoeo327's Avatar
Trader Rating: 75 (100%+)
I've boiled them, baked them, and tried acetone - acetone works best.
Work outdoors to avoid the headaches.
oeoeo327 is offline
Old 05-16-2014, 06:55 AM
I thought the Acetone would ruin the Rubber
wragusa is offline
Old 05-16-2014, 06:58 AM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Only rubber I've seen affected is off road clay compounds. Not sure if any on road compounds would be affected.
racer1812 is offline
Old 05-16-2014, 07:17 AM
These are for off road Rubber tires
wragusa is offline
Old 05-16-2014, 08:22 AM
moparSRT's Avatar
Hpi d-compound tires shrink and harden in acetone.
moparSRT is offline
Old 05-16-2014, 08:40 AM
Really??? I've never experienced that. The foams dont seem to like it very much though.
Old 05-16-2014, 09:27 AM
So what do i do ?
wragusa is offline
Old 05-16-2014, 09:43 AM
chasingthepack's Avatar
speak to malc hall,thecoolcanfanman,youll find him through the arc r10 thread,he brought out a product 10 yrs ago that did the job,only downside was some wheels would melt in the solution
chasingthepack is offline
Old 05-16-2014, 10:22 AM
Trader Rating: 70 (100%+)
I was wondering about this too. I want to remove/clean my jacos and reglue them. I wish all those spec tires would come unglued.
PROMODVETTE is offline
Old 05-16-2014, 10:38 AM
Super Moderator
racer1812's Avatar
I know what you're asking, my post reflects my experience with a known compound. Which lets other members who may know of any similar compounds comment on which ones may be affected. Since you don't say which tires you're trying to remove.
moparSRT's Avatar
they shrunk when I left them in acetone over night, they were fine for a couple hours.
Acetone looses its strength over time/use, with fresh acetone I can remove tires in as little as 1 hour, with used acetone it takes a lot longer. And yes it will destroy some inserts.
moparSRT is offline
Old 05-16-2014, 11:01 AM
Trader Rating: 13 (100%+)
i use a 5 gallon bucket with a little acetone poured into the bottom. then i put the wheels/tires on a wire rack to suspend them above the acetone. i then seal the jug and reopen the next day.
experiences may vary, but ive never lost a wheel, foam, or tire using this method.
turbo4age is offline
