Tekno ET48 Thread >
Tekno ET48 Thread
Like Tree38Likes
Tekno ET48 Thread
Old 05-13-2014 | 07:37 AM
  #2761
Originally Posted by werner sline
ehm, wait a minute : is the et48 left 4 Wheel steering ?? great idea ! how does it drive ?
Yep, 4WS...drives awesome, love it! Still getting them both tweaked perfect to give a real good comparison though. Couple video links below.
https://www.youtube.com/watch?v=lSZd_0c_it4
https://www.youtube.com/watch?v=xHGE5WXmgss
Djameso is offline
Old 05-13-2014 | 07:47 AM
  #2762
Got a new basher video if anyone wants to check it out. Some pretty sweet backflips.
https://www.youtube.com/watch?v=fge4QXJv9DA
Djameso is offline
Old 05-13-2014 | 09:18 AM
  #2763
Cool looking 4WS setup! And nice backflips too.
MattP is offline
Old 05-13-2014 | 09:35 AM
  #2764
boudin4evr's Avatar
Originally Posted by munrath
Marc,
15* spindles will make it easier to drive but will not provide as much initial steering going into the corner. The 10* spindles will allow you to enter into the corner, will make the steering a little more sensitive and you will loose some mid-corner steering on power. You can play around with the kick-up in the front to find a happy middle depending on which way you go. I like the 10* spindle over the 15* for the track's I've been running on.
Hope this helps,
Mark
I always struggled with my rc8t
maybe not agressive enough in the 180's!?
my truck is built, ill drive it like that but noticed you use 10* spindles
was wanting to know how much difference there was and how it acts with each! I have your setup minus the 10*
ill go with that til I order parts later
thanks!
boudin4evr is offline
Old 05-13-2014 | 12:06 PM
  #2765
Marc,
It really comes down to personal preference. I always carry both 15 and 10. If it's a really rought track I may choose 15 over the 10 just to smooth it out. If the track has tight 180's then I'll go with the 10, if it's fast and flowing I may go to the 15's.
Hope that helps,
Mark
munrath is offline
Old 05-13-2014 | 06:58 PM
  #2766
boudin4evr's Avatar
Thanks Marc, I have both stock and 15 degree as well as stock and +1 rear hubs, I just went through my spares!
I'm going to 2 new tracks, 180's were always my weak areas
Old 05-15-2014 | 12:40 PM
  #2767
Mizchief's Avatar
i learned with 180's and tight turns in general is that you have to break at least a little bit before hand to get the weight back on the front wheels before turning in more so than on a buggy where you may instead just throw the rear into the turn to slow down.
Mizchief is offline
Old 05-15-2014 | 07:20 PM
  #2768
Thanks Matt!
Djameso is offline
Old 05-16-2014 | 03:06 PM
  #2769
One Mile Up's Avatar
Looking into picking one of these up as my first truggy... I am a complete noob and am reading up as much as I can...
I am wondering though if someone could explain to me the different motor/esc shenanigans... specifically the kV of a motor in conjunction with the battery being used.
If you could even just link me to somewhere where it is explained in greater detail I would really appreciate the help!
Thank you.
One Mile Up is offline
Old 05-16-2014 | 05:09 PM
  #2770
DCNash55's Avatar
What bodies fit our trucks with little to no modification?
DCNash55 is offline
Old 05-16-2014 | 05:17 PM
  #2771
Originally Posted by GrimReminder
Very nice. Could you post some photo's from the side, front, and from underneath? I like that body, so before I go swoop one up I would to see how it really fits. I appreciate your help.
thanks man...sorry for the delay...I gave a close up of the front wheel well so you can see the cut outs necessary to run LARGE wheels and the space needed for the front camber links - I probably will dremel out the entire wheel well flares for a cleaner look, but I'm trying to live with it for a bit. All of this would not have been needed if I figured out a way to mount the front end of the body higher. Important to note, I used the Proline mounting system by driving the threaded screws into the wing mount. This way, I can quickly swap out and replace with the wing should I want to run the original body. Diversity boys!
Attached Thumbnails Tekno ET48 Thread-et48side.jpg   Tekno ET48 Thread-et48rear.jpg   Tekno ET48 Thread-et48-front.jpg   Tekno ET48 Thread-et48-wheel-well.jpg
Hungryarch is offline
Old 05-16-2014 | 05:18 PM
  #2772
see what I just posted...
Old 05-16-2014 | 05:20 PM
  #2773
Originally Posted by Djameso
Looks Awesome!!! We've got a smart one here running a ford body!!!
Thank you sir! My old man was always a Ford guy...gotta love the classics.
Old 05-16-2014 | 06:16 PM
  #2774
DCNash55's Avatar
Race bodies is what I am after...
DCNash55 is offline
Old 05-16-2014 | 06:29 PM
  #2775
FastPete's Avatar
Sweet, now video when you give it a whirl!
FastPete is offline
