Team EPIC REVTECH "4XS" Quad Magnet 12 Pole 540 Brushless Motor >
Old 12-11-2013 | 05:19 PM
  #181
ahutchinson's Avatar
Yes total of four. Be careful with the green oring they wear out easy so keep it clean and check often.
ahutchinson is offline
Old 12-12-2013 | 02:52 PM
  #182
derekbsmith's Avatar
thanks for the help, but no thanks to trinity support. emailed them with their thoughts on this, w/no reply.
derekbsmith is offline
Old 02-17-2014 | 01:01 PM
  #183
If I'm running my Tekin Pro4 4600's using a 15 pinion and swap over to the Revtec 4800 4x12 SC, What gear would u guys advise I try running. This is on the same track, same layout.......
TravisT is offline
Old 03-11-2014 | 06:28 PM
  #184
Does Anyone have a pic of the timing on there revtech they could text me. 828-691-1582 thanks
Old 05-10-2014 | 12:32 PM
  #185
OfnaJoe's Avatar
Is this right? Is the o-ring suppose to be on the brass spacer? I have a heat issue I can't find the reason for and thought about the spacers?
OfnaJoe is offline
Old 05-11-2014 | 11:34 AM
  #186
I'm looking for the rear bearing size (on the 5mm version), as mine has worn out.
Any help would be much appreciated!
Winx69 is offline
