Kyosho Ultima SC6 Thread....... >
Like Tree9Likes
Old 04-24-2014 | 11:16 AM
  #196
Originally Posted by Johnn27
My truck arrived yesterday! Debating on RR or MM configuration?
From the set-up sheets I have seen looks like rear motor for now!
Any feedback on rear v. mid???
If you're on high bite I'd go mid. Its going to require a couple of simple mods like a super short front camber link (use one from an RB6) and red rear springs....you'll be dialed.
QDRHRSE is offline
Old 04-24-2014 | 11:49 AM
  #197
any sugestions for a outdoor track setup? Im assuming the setup included in the kit is for a indoor clay track.
J-RO is offline
Old 04-25-2014 | 12:29 PM
  #198
4 hole pistons, 32/37 weight oils
D34DM0053 is offline
Old 04-25-2014 | 03:35 PM
  #199
Are the arms and stuff the same or is everything different? If it's all different then where y'all buying arms and parts thanks
bdoghentschel is offline
Old 04-25-2014 | 06:41 PM
  #200
http://www.kyoshoamerica.com/assets/...odyT_JBRL2.pdf
Cody's setup
Ruinms is offline
Old 04-26-2014 | 04:56 PM
  #201
1967rs's Avatar
I got the chance to run mine today for the first time. Mid motor on an indoor high bite wet clay track. The truck is really good. I qualified 4th in the A and finished 4th.
1967rs is offline
Old 04-26-2014 | 06:04 PM
  #202
^^^^ what place did you normally run before the new truck?
J-RO is offline
Old 04-26-2014 | 06:44 PM
  #203
1967rs's Avatar
With the group that showed up today I would normally be top of the B or bottom of the A. Keep in mind this is no practice just running an untested set-up. I would likely have done better but I got taken out on the first lap and was in last.
A fellow racer (better driver then me) also had his SC6 at the track for the first time (he has not ran sct in more then a year) he qualified 2nd and finished 2nd.
1967rs is offline
Old 04-26-2014 | 10:01 PM
  #204
bignik957's Avatar
^^^^^ Almost same set-up I ran tonight except I ran 42.5/35 shock oil with A killshot high tourque motor with maxzilla rotor geared 75/25 with cut gears in transmission truck was super stable and planted
bignik957 is offline
Old 04-27-2014 | 05:56 AM
  #205
Is this boosted 17.5 gearing?
Vincent_Diesel is offline
Old 04-27-2014 | 06:06 AM
  #206
Default Mid motor body holes
In anticipation of the SC6 arrival I had painted a body beforehand and waited for the truck to be built before I drill body holes. Decided on a Proline EVO SC.
Overall body fit well but the rear body holes are dangerously close to the rear edge of the body. Based on experience this part of the body is a weak point and rather find an alternate to the rear body post location, closer to the rear shock towers would be ideal.
I don't think there is a work around for this, unless I'm doing something wrong.
Old 04-27-2014 | 08:03 AM
  #207
Lowe's48's Avatar
I'm thinking about getting that motor. How's the temp? How do you like it compares to other motors?
Lowe's48 is offline
Old 04-27-2014 | 08:04 AM
  #208
Lowe's48's Avatar
Got pics?
Lowe's48 is offline
Old 04-27-2014 | 12:38 PM
  #209
1967rs's Avatar
My 76/28 is blinky thou my d3.5 17.5 also has the HT rotor
1967rs is offline
Old 04-27-2014 | 05:06 PM
  #210
bignik957's Avatar
that is blinky gearing
