TAMIYA M-06 Thread >
TAMIYA M-06 Thread
Like Tree121Likes
TAMIYA M-06 Thread
Old 04-18-2014 | 08:44 AM
  #1486
anybody know if the Tamiya steel gear fit in the 3racing gear diff ?
Quinny45 is offline
Old 04-18-2014 | 09:18 AM
  #1487
Raman's Avatar
Are you planning on running a mod motor?
Raman is offline
Old 04-18-2014 | 09:40 AM
  #1488
I run 17.5 motor.... I ordered the 3racing gear diff and I have a extra steel gear set... mod motor or not I juste want to know if they fit
Quinny45 is offline
Old 04-18-2014 | 12:35 PM
  #1489
Originally Posted by Raman
The 417 knuckles at this point are theoretical, no ones has tried them out yet. None standard.. Some run the 3 racing gear diff since it's lighter.. That's about it though
Will the 3racing Gear Diff work with the Tamiya Gearbox?
What weight lube has been working best?
A-Ko is offline
Old 04-18-2014 | 04:44 PM
  #1490
Raman's Avatar
Yes it's designed for the M05/M06. I run the M05 ball diff. Check one or two pages back.. There are some diff oil weights listed.
Raman is offline
Old 04-23-2014 | 03:15 PM
  #1491
hey , i have my m06 , that ill be running on med grip carpet , can anyone suggest a good starting set up , running m-chassis trf's , also have a 3racing gear diff , it has a 21.5t motor and a bit of timing ..
i'd appreciate any help ..
shaun207 is offline
Old 04-23-2014 | 03:25 PM
  #1492
Raman's Avatar
This what I run
60wt / yellow fr, 60wt / blue rear. Gear diff, I will let someone else chime in since I run ball diff. Ride height 5 mm rear and 4 mm front. I also run 1 degree rear up rights, camber - 2 in rear and front 0 degree. I also run with zero toe out in front
Raman is offline
Old 04-23-2014 | 07:41 PM
  #1493
MD's Avatar
MD
I ran these tires this weekend on a medium to low grip carpet and they hooked up well. I ran the mediums in the front and the softs in the rear with hard inserts in both.
http://www.tqrcracing.com/shop/produ....asp?p_id=1849
http://www.tqrcracing.com/shop/produ....asp?p_id=1848
MD is offline
Old 04-23-2014 | 07:43 PM
  #1494
Raman's Avatar
Shimizu are nice tyres. For inserts I use the sweeps pink soft insert all around.. the inserts that come with Shimizu are not very good.
Raman is offline
Old 04-24-2014 | 02:05 PM
  #1495
This what I run
ok thanks for your help , last question , can you remember what pistons that was ? ive had 2 mo6's before , last one was dialled , just can't remember my set up from it .. thanks again
shaun207 is offline
Old 04-25-2014 | 12:57 PM
  #1496
Raman's Avatar
I'm presently using 3 hole pistons front and back
Raman is offline
Old 04-25-2014 | 04:19 PM
  #1497
ok thanks , last question !! shock lenghs ??
i ran the car tonight , it was ok , found it a bit inconsistent , played about with springs , it either was spot on , understeer , or grip roll !!
, however i did find a problem with the front shock tower ( it was loose ) , that will proburly exsplain why it would digg in the spool the diff up !! will change the pistons for next week ..
shaun207 is offline
Old 04-25-2014 | 04:51 PM
  #1498
MD's Avatar
MD
You may want to watch this video. It has some setup tips.
http://www.youtube.com/watch?v=ANzz-xIgX4c
MD is offline
Old 04-26-2014 | 10:13 AM
  #1499
Raman's Avatar
In the front I have 3 o rings, basically not droop whatsoever. Rear I have full shock length.. You need it because it's hard to keep the car at 5mm ride height.
I raced again last night against the field of 1/18. The same 2 fast guys held 1st and 2nd and I consistently was 3rd. I worked on increasing my confidence with corner speeds and smoother transition in the infield. It's starting to pay off.
We race on asphalt and yesterday was super windy as well.. Nonetheless I had very consistent traction.. Not bad for a RWD!
Raman is offline
Old 05-18-2014 | 11:57 PM
  #1500
wollow86's Avatar
Dusted off my m06 for a run yesterday and was very happy with where I got the car to.
Qualified 3rd, finished 2nd. Only 06 in a field of 05s. Medium outdoor, boral asphalt paint.
Mid wheel base, Ride BRZ body. Standard battery, reward position.
Ride SC32 rear, and MC34 front all on inch up rims.
Yellow front spring blue rear, 60wt oil front and rear. 3 hole pistons. Option rear damper stay, outward mounting position, standard lower arm mounting.
1.5 rear toe.
Ball diff, alloy rear stiffeners and lower front plate are the only other hop ups.
The car was really good on this setup, still hunting for a little more on power steering, but it's very close.
wollow86 is offline
