Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree141Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 03-31-2014, 12:30 PM
  #7606
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
Originally Posted by Chris Gierse
Thanks Matt. Do you have a part number for the 1mm shims?
just search 1mm shim on amain. i use the ASC4617 for ball stud washers, they come with .5, 1 and 2mm shims.
Matt Trimmings is offline
Old 03-31-2014, 01:12 PM
  #7607
Trader Rating: 165 (100%+)
Thanks for the info. I thought maybe they had a specific part # for this.
Chris Gierse is offline
Old 03-31-2014, 01:19 PM
  #7608
1evo RRR Driver's Avatar
Trader Rating: 11 (100%+)
The schelle spur gears are molded out of a different material and are quieter. I am not sure how long avid will continue to sell the triad. Kurt (the guy who designed the Triad) just started Schelle and owns the rights to those designs.
Thanks for the info
1evo RRR Driver is offline
Old 03-31-2014, 01:54 PM
  #7609
Originally Posted by Jordan Anderson
I heard someone locally actually got a B5M kit late last week.
Anyone else got their B5M yet?
My local shop (Mike's RC World in Bellingham WA) had them a month ago
Justinb86 is offline
Old 03-31-2014, 02:13 PM
  #7610
azwheelman's Avatar
just got it last sunday @hobbytown srs there last 1 of 6
still needs electronics
Attached Thumbnails Team Associated RC10 B5m Mid-Motor & Rear Motor Thread-20140329_122419.jpg
azwheelman is offline
Old 03-31-2014, 02:16 PM
  #7611
RCBuddha's Avatar
Trader Rating: 40 (100%+)
Still waiting for Amain. They have the ETA as 4/15/14.
RCBuddha is offline
Old 03-31-2014, 02:35 PM
  #7612
rigor's Avatar
Trader Rating: 44 (100%+)
Actually Jesse, its the position of the front caster block. You shim it differently to maintain wheelbase. AE shouldnt have said "rear casterblock" It should have just said casterblock.
Good catch! Caster only exists up front.
rigor is offline
Old 03-31-2014, 03:20 PM
  #7613
pumpkinfish's Avatar
I'm about ready to install the D arm mounts. Which way do the arrows point on the inserts? I also am guessing that on the C arm mounts the number that is installed on top of the insert is what setting the car will have.
pumpkinfish is offline
Old 03-31-2014, 05:13 PM
  #7614
Trader Rating: 32 (100%+)
Originally Posted by rickster
hey skeeter ..
if you can post your current setup and equipment your using then I can help you from where you are to get as much steering as you would like.
I would love to fill out a sheet and post it but im not very pdf or jpeg savy. Its hard for me to even load pics on computer, i know ha ha laugh all you want im a dumb-a** but anyhow. Ill try my best to list everything
FRONT:
Camberlink inside on tower with 2mm under B.S.
1.6 piston 32.5 wt. white spring, middle on tower and outside on arm
4mm trail, casterblock spaced forward(stock), no bumpsteer spacers or ackermann changes.
Chassis Elecs. Shorty all the way back to tranny, (helps with rear grip)?
REAR: 1.6 piston 32.5 wt GREEN spring middle on tower inside on arm
camberlink: Inside hole(closest to tranny) 2mm B.S. washer under it,
Middle on the 3-hole option on rear hub w/ stud @ top
Hubs spaced all the way back
Anti-squat is whatever the manual says to run!
Skeeter36 is offline
Old 03-31-2014, 05:42 PM
  #7615
Does anyone know what a stock b5m weights without battery?
I was depressed today I weighed mine. Came in at 1609 grams RTR. My battery is 212 grams so I can save 60 grams there. I'm running titanium screw kit and turn buckles. Along with aluminum top shaft. Carbon fiber battery strap and a few aluminum parts.
Far cry to 1500 grams.
splking1 is offline
Old 03-31-2014, 05:47 PM
  #7616
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Alum upgrades to replace plastic parts will mostly likely add weight. IMO the best place to lose weight if you a weight crazy person is in the esc and servo. The tekin rs gen2 and a light weight low profile servo is about as light as you can get. Plus the 150gram battery would get you very low.
Wildcat1971 is offline
Old 03-31-2014, 05:56 PM
  #7617
thecman26's Avatar
Trader Rating: 112 (100%+)
Originally Posted by Logi Maker
Looks like the B4 ones. How are those supposed to work on the new axles or do you need different ones?
You have to have part 91408, clamping axles too. Most places are sold out of those, The had some at GS Hobbies last week.
Now Nitrohouse shows back order on the 91409's.
thecman26 is offline
  #7618
Yeah the low pro servo will save 21 grams and battery will save 57 grams. So that will put me at 1531. As for the aluminum part I weighed all then compared to stock plastic. It added 3.2 grams compared to stock.
I'm running the lrp flow now. I'm sure it's heavry than the tekin.
splking1 is offline
Old 03-31-2014, 06:06 PM
  #7619
i dont know why so many are obsessed about getting to minimum weight.. unless your racing the stock nationals you really don't need to worry about it... if you cant beat the guys when your car is 1550 grams your not going to beat them at 1500 grams..lol
rickster is offline
Old 03-31-2014, 06:20 PM
  #7620
Trader Rating: 17 (100%+)
To me it makes a huge difference with the way the car jumps. The lighter car is going to accelerate better and jump better then the heavier car, I was not a huge believer till I ran a light car and a heavy car back to back - it makes a difference. Also, I think there are a number of guys in this thread who very well may be in the main or close to it at the stock nats, so there is that too.
Kave is offline
