#5086
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
built my B5m kit last night but had on problem....One of the blue adjustable shock collars would not screw onto any of the shocks. Seems there is a problem with the threading on the collar as all the other collars screw onto the shock bodies just fine.
I faxed a request in to AE. Hope they can send me one ASAP.....I want to race! Or does anyone know where to buy them?
#5087
Got to drive a friends B5M right after I finished up racing my B5R this weekend. B5M is definitely faster in the turns, whereas the B5R is faster in straight lines, and does not become as upset over the ruts that have developed at LRH. Both are excellent cars, and will be winners, just depends on your track, high bite clay with a lot of 180 degree turns, and chicanes, B5M, looser bumpier conditions B5R.
#5089
This is already wrong because the surface area that is avaible on compression is bigger then it is on the rebound.
The 3mm shaft and 12mm bore in this case make the avaible surface on rebound is 6.25% smaller.
Thus even the flat piston has a lower resistance on rebound than compression.
#5090
#5091
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 40 (100%+)
Alright, so I have been out of the offroad thing for a small while now, but have my hands on both B5 and B5M. Debating selling the RM, perhaps.
Since I'm in LA, what do you local LA/OC guys recommend I keep if I only keep one car? I'd be going mostly to OCRC but I do want to try out other tracks in LA/OC.
#5093
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
#5094
A little confused , you now say the car is pretty decent.
Guess your push is gone ?
Set up your using is a great choice, don't try to change it too much.
Doublt the tire compound is wearing off.
so now suggest
Checking the faster cars for what tires ,inserts & traction compounds they are using.
Or even better git one of the fast guys to test drive your ride & try to drive his so you can learn the differences in just a few laps.
so now suggest
#5095
Look what the postman just dropped off. Looks like the daughter and I have a long night ahead of us. Need to head down to Burger King, grab some Whoppers and start building!
![](http://i469.photobucket.com/albums/rr57/MapleBoarder78/0091024x672_zpscd31ff7a.jpg)
#5096
just finished my build,wow a lot different then my b4 buggy and my t4.2 i built last week,plastics are a lot better,shocks feel a lot more plush then my t4.2 shocks,not sure if its because the seals fit a lot better in the body but they are butter smooth.I ended up with thielke setup to start with and see how it is. How is everyone running there shortys? back or forward? also are you adding weight anywhere to the car? my track is med bite and tires are ss/soft or some really sauced up clays.Waiting on my lid to be painted and my tires now
#5097
I'm running the pack forward. I would only run the pack backwards outdoors. I tested both and forward felt significantly better to me. No weight was required for plenty of steering indoors with 2mm trailing axle setup.
#5098
#5099
#5100
