The Speed Passion Thread
Thank you for taking the time to answer.
I am using a hobbywing Extreme stock 60A esc and a hobbywing XERUN 21.5 (no end bell timing).
The last big event i ran the below settings to finish 5th in the A-Main.
using the extreme stock esc.
No end bell timing
boost 50 (0.6 * 50 = 30 degrees)
Turbo 14 (0.6 * 14 = 8 degrees)
Start rpm 3000, increasing every 300 rpm
Turbo delay 0.1
FDR 5.44
99 degrees F day, motor temp 180 degrees F (outer case) after 6mins
I would like to achieve something similar using the Reventon, I like the SP esc's, they are way smoother than the Hobbywing, but I am struggling to balance speed and heat with the SP reventon esc.
So if hybrid boost active is a % of 30 degrees, that make sense.
But if the rpm on a 21.5t boosted motor is 24-30K then how is the hybrid boost of 150K related?
No end bell timing
Turbo delay 0.1
FDR 5.44
and is WOT wide open throttle?
I have just got a Reventon Pro 1 and want to run it in my spare car with 17.5T motor in boosted settings, but do not understand the SP settings. Like it or not HW & Tekin settings are a lot easier to understand, especially with regards to the hybrid boost start points . Anyone like to share their set up for a 17.5 boosted or even a 13.5T boosted please
I'm trying to start smoothly my Reventon PRO 1.1.
When you push throttle, at the begining, don't moves tires (reduced neutral range) but allways starts fast, seems impossible to see tires moving slowly.
It's normal?
3 drivers in my track with the same problem, different motor and radio.
It's normal?
| + YouTube Video | |
Help needed!
I'm trying to set a friends pro 1.1 EX up with the WiFi module but I can't update the firmware.
It connects fine if I don't put it in safe mode and I can edit all the usual settings (ABS etc...). But in normal mode (not safe mode) the update firmware option doesn't shop any firmware available.
If I run it in safe mode it says it's connected but the red blobs at the bottom of the screen don't turn green. When I chose the firmware I want (Stock1) it goes to the update screen but then immediately fails. I get the message "Download failed, please reset the ESC". From this point on I can't do anything but reset the app.
I've tried everything and am all out of ideas.
I still can't update the firmware from the WiFi module which is pretty crap but at least I can adjust most settings.
I was really surprised to see iOS7 wasn't supported. Seems stupid considering most iphone users will be on that version.
No reply to this question?
Hi.
Running a Reventon-R with V1.1.0.24 stock01 on
V3-13.5t boosted in a Xray t4-13
Belltiming to max. = 10*
FDR: 5.9 (27/84)
DRRS: 8
HB: 90%
HB max: 150k
HB delay: 0,2
HB-start: 4000
Slope: 18*/0.1
Brake: 70
Drag-Brake: 20%
Our track is round about 40meter x 30meter:
Felling to less punch/turbo effect on the final line
Is there room for improvement on my setup..? :roll eyes:
FDR: 5.9 (27/84)
DRRS: 8
HB: 90%
HB max: 150k
HB delay: 0,2
HB-start: 4000
Slope: 18*/0.1
Brake: 70
Drag-Brake: 20%
21.5 Blinky Reventon S with the 21.5R v3.0. Motor currently has the stock timing board. 3 varieties: 21.5 Blinky F1, 21.5 Blinky LM-1 and 21.5 Blinky USGT. The question is, what timing board should I use for each class?
Hi.
FDR: 5.9 (27/84)
DRRS: 8
HB: 90%
HB max: 150k
HB delay: 0,2
HB-start: 4000
Slope: 18*/0.1
Brake: 70
Drag-Brake: 20%
FDR: 5.9 (27/84)
DRRS: 8
HB: 90%
HB max: 150k
HB delay: 0,2
HB-start: 4000
Slope: 18*/0.1
Brake: 70
Drag-Brake: 20%
I have no fan on the motor - maybe it will help
I'm not running a fan either and use this setup at every track.
Have you tried another motor/checked the V3 bearings, cleaned internals etc? Is your drive train running free?
That's weird, I run the same settings except for minimum onboard timing with the 13.5MMM motor and the motor never gets to 80c and I've never had the ESC switch off? I find the speed, punch and acceleration really good.
Hi, i have a V3 13.5R, I've ran it boosted and has been performing quite well since i got it last year. But this afternoon my car just stopped on the tracks. Then i noticed when i picked it up and throttled it was running but when i put the car down and tried running it again, it won't even move an inch.
What's wrong with this motor and what can i possibly do without replacing it?
Thanks in advance.
Thanks in advance.
57Likes
