Anybody swap/modify 4PLS trigger? Bit tight >
Old 02-27-2014 | 04:36 PM
Default Anybody swap/modify 4PLS trigger? Bit tight
Guys, wondering if anybody has swapped or modified the stock trigger...big fingers and it real tight. Thanks
kirkham is offline
Old 02-27-2014 | 05:12 PM
Odin544's Avatar
Lots of people modify their triggers. You can try a little heat and then open it up. I would however pull the trigger out of the TX before doing so though.
Odin544 is offline
Old 02-27-2014 | 06:33 PM
Fegbri46's Avatar
I noticed the tightness too. Just got one and would be interested in this also. The heat method scares me though. Afraid I would snap it by accident.
Fegbri46 is offline
Old 02-27-2014 | 07:21 PM
Odin544's Avatar
You would heat it until its soft and pliable. So it wouldn't snap. It would take very little pressure to move. Once the plastic cooled it would be stiff again.
Odin544 is offline
Old 02-27-2014 | 08:07 PM
asc6000's Avatar
Didn't your parents buy you any plastic models when you were a kid ?
asc6000 is offline
Old 02-27-2014 | 08:10 PM
Fegbri46's Avatar
You love breaking my stones asc6000! They did, but never had to heat up and bend. I haven't even run the car yet, so prob should do that first before modifying anything. Thanks though.
Fegbri46 is offline
