Recommend a soldering iron
#32
I have owned several different soldering irons over the past 24 years or so. All were relatively inexpensive ones so I don't have experience with any of the high end ones. But out of all that I've ever had, by far the best one is the current one I bought from Hobbyking- http://hobbyking.com/hobbyking/store...arehouse_.html
It heats up quickly and works very well. I like the adjustable range which is perfect for rc use.
#33
#35
#36
#38
weller or hakko (or rebranded hakko, lots exist) would be a good all around soldering station. with VERY few exceptions, any soldering irons that don't have a base station are nearly unusable and junk. there are exceptions like I said, but very rare. you can get a nice hakko rebranded station for ~$50
if you have the money and will be using it a ton, you can't go wrong with a JBC. i have their modular series and they're top notch! but I'm into electronics as a hobby so it was worth every penny. would be excessive for just soldering the occasional battery connector
#40
I keep this one in my track bag its got enough power for just about anything and I like the adjustable temp feature.
http://www.radioshack.com/product/in...uctId=12604264
I also have a hakko at home on my workbench.
#41
http://www.ebay.com/itm/10PCS-Solder...item4854dff8dd
5th one from the left is the work horse. Single Hakko tip is $4.50(you want a 3c or 4c), worth the convenience if you find one locally. Otherwise, order these.
#43
From: Everett WA in the Summer Mesa AZ in the Winter
Another Hakko user here but I recently picked up a Weller Portasol butane powered iron for use at tracks with no electricity. I was really surprised by how quickly it heats and how well it worked even in windy conditions on big motor wires. Get the biggest one. Supposed to be equivalent to a 125 watt iron.
I'm keeping the Hakko on the workbench and using the Weller exclusively at the track.
#45
If your just looking for an iron, the Trakpower TK60 from Tower Hobbies is very good, gets super hot, and costs $16. The problems are a stiff cord and sometimes too hot, but for $16 a real bargain. I will probably get the Hakko next as well.
