Nitro On-Road
#2221
LAST DAY FOR ALL THE NEW GOODIES!!!!!!!!!!
WE WILL BE CLOSED TILL THE 30TH SO THIS IS THE LAST CHANCE FOR YOU TO PICK UP ALL THOSE NEW GOODIES!!!
PROTOFORM BODIES
PROTOFORM WINGS
PROLINE TIRES AND BODIES
NOVAK GTX
NOVAK MATCHED BATTS
NOVAK SMART TRAY
NOVAK HEAVY DUTY ESC
NOVAK XXTRA AND XXL
YOKOMO SDW
YOKOMO CGM
YOKOMO HOP UPS
YOKOMO DRIFT TIRES/WHEELS/BODIES - NEW!!!
RAYSPEED HOP UPS
LOSI LST
TRAXXAS REVO
TRAXXAS EMAXX
PARMA NITRO SCENTS
AND CRAP LOADS MORE!!!!!!!!
HAPPY NEW YEAR!!!!!!!!!!!!!!!!!!!!!!!
capitol speedway closed on 31 Dec and 1 Jan
PROTOFORM BODIES
PROTOFORM WINGS
NOVAK GTX
NOVAK MATCHED BATTS
NOVAK SMART TRAY
NOVAK XXTRA AND XXL
YOKOMO SDW
YOKOMO CGM
YOKOMO HOP UPS
RAYSPEED HOP UPS
LOSI LST
TRAXXAS REVO
TRAXXAS EMAXX
PARMA NITRO SCENTS
#2222
guys ang hirap nang i start ung engine ko (gs15r) to the point na lumalaki na ung biceps ko ayaw pa din mag start... nu kaya problem nyan?? minsan ayaw pa bumalik ung pull start.. gagalawin ko pa ng konti ung flywheel para bumalik... hrrrr.. nu kaya problem?? if ever how much ba mag pa tune up ng engine??? salamat!
#2223
Just be patient!!!
1. Make sure glow plug is good.
2.Make sure Igniter is good.
3.Make sure there is fuel on the line or @ least right by the carb.
4. Check if your fuel is still good. One time I had a lot of problems from O donnell 20%. Some of us might have a different opinion, but I did had problems with bad fuel especially here because its most of the time cold.
Hints!! Do not pull as much as 2 feet, this is not a lawn mower. If everything was correct 2 to 3 pulls the motor should start.
GS motors from Kyosho is like OS. So just try this. HIgh needle 3 from close, Low end 2.5 from close. Also, make sure that the line or the carb does not have a leak!!!
Hopefully this works and have fun practicing.!!!!!
BTW! If you just here in Chicago Every tuning is free. There are lot of Engine GURU here.
#2226
pano ba i check kung ok pa un glow plug? diba pag tinangal mo ung plug sa engine tapos kinabit mo sa igniter mo dapat iilaw un.... tama ba???
and how much ba isang gnun??? salamat!!!
#2227
From: Cebu City, Philippines and Ocala, Florida, USA
#2228
#2229
Originally posted by cabworks
you can try sa fort bro, SPEEDZONE..
#2230
Originally posted by doki_doki
woah...may races ba for 1:8 scale on road kits??? ganda tingnan nun ah...very fast
#2231
tama yan pare... you could also check if hindi ba deformed yung coil nang glow plug mo. if deformed na then it's time to change it. a standard glow plug cost around P200-P250. i recomment using OS glow plug #8 for your GS15R engine. i've tried using it na with Kyosho engine and no problems with it...hope this helps pare
#2233
Originally posted by buboy28
doki doki, d ko alam kung nagkaroon na 1/8 on road race dito manila pero ang alam ko race track na pwede venue nuon ay sa montalban race track kasi yung lang ang alam ko na pwede ang 1/8 na kits
#2234
From: Costa Del Sol, Marbella, Spain www.bradir.net
have you seen one of raywood's rc videos? check them out here at www.raywoodrcvideos.com
#2235
