DuraTrax IntelliPeak ICE DC Competition Charger
#1922
Sorry it didn't help. I'm not sure getting one repaired is much of an option these days versus trying to pick up a good opcndition used one.
Mine flaked a while back while doing a 10a discharge and I just replaced it with a TC 1030.
#1924
This worked for me: Take it apart, start by removing the end caps, then the front panel lifts off if I remember correctly. Work the buttons while spraying liberally with motor spray. Let dry thoroughly then reassemble. Did this to a pair of them and they have worked fine since.
#1927
i'm still using this charger to charge my lipo batteries..
is setting the max charge betweeen 50 - 80% same as like charging in storage mode?
any thoughts about hyperion LBA10 balancer? i'm planning to buy one for balance charging..
thanks guys..
thanks guys..
#1929
Does anyone know why this charger was discontinued? I mean, pound for pound, this charger has a heck of a lot more features than some of the "new chargers" out there. I just bought the 10 amp Team Orion Advantage Advance. It's pretty with the touch screen and all... But once you get over the novelty of the touchscreen, you realize that it has LESS features than the ICE...
The only thing that I don't get with the ICE that I get with the Advance is balance charging and 10 amp charging vs 8 amp charging, built in AC power supply, and peaking Lipos over 4.20 volts.
Some of the key features that the Advance is missing that the ICE has are 10 memory settings (Advance has none!), 10 amp "true" discharge not limited to voltage of the battery, temperature sensor (Advance supposed has this but it doesn't work). So I feel like I wasted my money...
#1930
Agree the ICE has some interesting features, I use still them for discharging. But no balancer is a pretty big limitation these days. They are also painfully slow on the CV portion of a lipo charge. Memory settings are available, a couple generation old Hyperion Duo3 has 20 per port for example.
#1931
http://www.amainhobbies.com/product_...Voltage-Tester
#1932
That will work to a point. But if a pack develops more than minor issues it won’t be able to keep up, and the external balancer can’t reduce the main charge current like a built in balancer can to prevent a cell from being overcharged.
Just out of curiosity, did it some with any specification for drain/balance current? I don’t see anything listed on the site.
#1933
#1935
Does anyone have issues with batteries puffing prematurely using this charger? I am still using mine after years of faithful service but I am starting to have too many lipo batteries puff/swell during their early life to be just coincidence.
Doesn't seem to matter what the brand of battery... I only race once a month but I am careful about how I look after my packs
Is there anything else I could be doing wrong to cause this?
