Go Back  R/C Tech Forums > International Forums > Manila Racers
The Big Locked Thread >
View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
Like Tree1Likes
Old 12-22-2004 | 06:43 PM
  #4531
miniracer's Avatar
Originally posted by miniracer
Yokomo SD CGM - 8,500 only
- very fresh with box, manual and spares
- graphite parts and gears
- titanium turnbuckles
- aluminum front outer arm mount
- aluminum rear outer arm mount
- titanium front input shaft
- aluminum rear input shaft
- aluminum front & rear shaft holder
- rear blue aluminum cvds
- Xenon spur 96t 64P (bnew)
- RPM ball cups (bnew)
- yellow yokomo springs
09209209674
miniracer is offline
Old 12-22-2004 | 07:53 PM
  #4532
Default HPI RS4 3
RTR na.
very good condition. complete w/ box.
.15 Nitro Star Pull start engine
2 speed tranny
complete w/ radio n everything else
selling for only 16K pesos
09175360333
RND123 is offline
Old 12-22-2004 | 07:54 PM
  #4533
weng_888
Guest
Posts: n/a
Default Re: MSCC
Originally posted by Geetoo
.... mscc
does anyone know where this track located ?
Old 12-22-2004 | 08:29 PM
  #4534
buboy28's Avatar
Default Re: Re: MSCC
i think its in fort bonifacio the manila speedzone
buboy28 is offline
Old 12-22-2004 | 08:54 PM
  #4535
corsec's Avatar
for sale
factory team tc3, kit only
-aluminum threaded shocks
-aluminum cvd
-aluminum battery holder
-titanium turnbuckles
-aluminum servo and transponder mount
-graphite chasis,shock tower, suspension
-etc...
P4,000
0916 505 1097
corsec is offline
Old 12-22-2004 | 10:35 PM
  #4536
HAWKE's Avatar
EDIT.....
HAWKE is offline
Old 12-22-2004 | 11:12 PM
  #4537
A X O's Avatar
F OR S A L E
KO Propo EX 1 Mars Special Limited Edition
- Gold Series
- 40.775 Mhz
- Three (3) Receivers
- Box and Manual
- 6,900
ASSOCIATED FACTORY TEAM TC3
- Novak TC2 ESC (No Motor Limit)
- Futaba 9450 servo
- Stock Motor MVP
- Mod 10x2 Chrome
- Mazda Body
- Stratus Body
- Wheels and Tires
- 7,000
*Get Both for - 13,000
A X O is offline
Old 12-23-2004 | 01:56 AM
  #4538
S-T-R-l-K-E-R's Avatar
FOR SALE!!!!
PROTRAK
-charger (Ni-CD, Ni-MH)
-20 amp discharger
-battery monitoring system (will help you weed out those bad cells to revive your packs performance-will even tell you what cell should be replaced)
-temp charge tray (included) - for temp charging
-comes complete with bag, original wires, manual
-very well taken care of
-12K (firm)
ORIGINAL CGM SHOCK ABSORBER
-blue shock system of yokomo cgm
-still fresh (seldom used)
-will improve handling of yokomo 1/12 touring car
-will work on ALL yokomo TC kits
-great for back-up shox
-2K (firm)
RAYSPEED TRAY
-great for battery maintenance
-boosts performance
-protects your batts from over charging/discharging
-perfect working order no defects
-3.4k (neg)
JR XR2 CONTROLLER
-2 MODEL MEMORY
-EASY TO READ LCD
-DIGTAL
-27MHZ AM
-COMES WITH XTALS
-HITEC SERVO
-2K FIRM
YOKOMO TEMP GUN HARDLY USED
-BACKLIT
-LASER POINTER
-VERY FRESH
-SELDOM USED
-3.5 FRIM
serious buyers only pls.
WILL SHIP TO ANYWHERE
SERVICES OFFERED:
motor blueprinting (S-T-R-I-K-E-R TUNED)
-will get your motor up to speed
-price will be based on results that will be shown on dyno readings (before and after).
battery assessment
-revive your packs by weeding out bad cells
-ni-cd and ni-nh capable
-not available for stick packs
pls PM me for more info.
S-T-R-l-K-E-R is offline
Old 12-23-2004 | 02:23 AM
  #4539
work's Avatar
FOR SALE:
Yokomo SSG - 5k only
- Ti screws
- Ti axles (4pcs)
- alum rear hub
- alum suspension mounts
- alum rear cvds
- graphite shaft
- lots of spares
CE Turbo35 BL + TLP power supply - 9.5k only
- turbo is in good condition
- this is not an upgraded T35, orig na BL to
- power supply is defective but still working
0917 5331951
work is offline
Old 12-23-2004 | 02:27 AM
  #4540
Default looking for
pitshop boss: pa order naman na ng revo with phanton engine and parts needed para mag kasya yung engine. la ko mahanap d2 sa la. panay pull start pinakikita sa akin. jan 9 jan nako. ok lng bs yun????
Mdy111 is offline
Old 12-23-2004 | 03:41 AM
  #4541
Default HIGHWAYMAN'S CUP
JANUARY 16, 2005
CAPITOL SPEEDWAY
Race Details to follow
maebelle is offline
Old 12-23-2004 | 04:03 AM
  #4542
badboy's Avatar
Default Re: for sale
Originally posted by badboy
Turbo 35 BL (Stealth Edition) Php 12,000
TLP Power Supply (13.8v / 14 amps) Php 3,500.00
0917-8553115 (negotiable if you'll get both)
badboy is offline
Old 12-23-2004 | 04:13 AM
  #4543
kuuipo's Avatar
Default Re: x-mas sale!!!
futaba T2er stick type transmiter only/27mhz---php400
kyosho main rotor grip (SR) kyosho concept (eh 94)---php300
spur gear 64-116 / T23(kawada model/alloy/for losi xxxs)---php200
alloy rims for mini z---php300
tao3 aluminum parts rear c-hub/front knuckle arms/motor mount---php500
kyosho slick tires(high grip)w/inserts 1 pair---php200
tamiyaracing slicks w/rims 4 pcs. brand new---php500
for 1/12 carpet 4 foam tires---php400
1100mah ni-mh 7.2v. micro pack 6 cells for micro rs4---php400
losi xxxs parts arm graphite---php200
fm rx 4 xtal(type 27-1/ 26.995 fm)---PHP200
kuuipo is offline
Old 12-23-2004 | 04:45 AM
  #4544
rastaman's Avatar
Default SALE/SWAP
HPI RS4 3 EVO
NITROSTAR T-15 ENGINE
PULL START ASEMBLY
SHAFT DRIVEN DURABILITY
4 WHEEL DRIVE
2.5MM COUNTERSUNK ALUM CHASSIS
FULL BALL-BEARINGS
2 SPEED TRANSMISSION
REMOVABLE RADIO TRAY
OILFILLED SHOCKS
LOTS OF SPARE PARTS
4 SETS OF TIRES
ROTOSART INCLUDED
BOX AND MANUAL
9K
IF WITH KO PROPO FM EX1 CNTRLR, RX N 2 SERVOS - 11.5K
OR SWAP WITH HPI NITRO MT2 or ANY NITRO MONSTER TRUCK
PM / TXT - 0919-7101432
rastaman is offline
Old 12-23-2004 | 02:16 PM
  #4545
doki_doki's Avatar
From: Cebu City, Philippines and Ocala, Florida, USA
r/c stuff for sale…
NTC3 specs...
used ntc3 with blue rpm bumper, brand new factory team aluminum engine mounts (just opened, not yet used), factory team aluminum hex hubs, spare clutch bell with gears, stock rear exhaust pipe, stock rear exhaust manifold, used crowd plazer body, used sorex 40r tires with medium speedmind inserts mounted of speedmind rims, box, manual, basic set-up tools that came with the kit.
---> only for P5,000
V-ONE-R specs...
used v-one r with gpm aluminum pulleys (27T, 19T, 18T), kfactory aluminum brake pulley (19T), gpm rear nylon arm, kawahara chassis, kawahara brake disk, 3racing brake lever, kfactory carbon brake bracket and rear stiffener, kfactory aluminum radio plate supports, kfactory aluminum heat sink engine mount, aluminum threaded shocks, used sponge tires, slightly used chrysler 300m painted body.. don't have the original box and manual na but i do have a photocopy of the original manual. i'll throw in some extra parts i can find. ---> only for P5,000
OSTR engine very well maintained. In good running condition. only for P3,000.
used futaba fail safe and dynamite failsafe ---> only P500 each (free shipping)
almost brand new x-ray fk kit. with box and manual. very fresh. ----> only for P15,000 (PENDING DEAL!!!)
almost brand new futaba mc330cr esc (with box and manual) ---> SOLD!!!
you can reach me at 09176253484
selling for a friend…
M8 radio with novak 75mhz synthesized transmitter module with novak 75mhz synthesized receiver. box and manual included -----> P10,000
Hudy Ultimate Set-up System -----> SOLD!!!
Novak Brushless Motor (very fresh) -----> P10,000
Novak Smart Tray (very fresh) -----> P4,500
Novak GT7 ESC -----> P4,000
all items negotiable…text me your best offer as long as it’s reasonable…
doki_doki is offline
