VBC Lightning 12 >
VBC Lightning 12
Like Tree3Likes
VBC Lightning 12
Old 11-20-2013 | 02:35 PM
  #136
I'm not sure where you see a hole but that is my car and there is not one. I am going to put a hole in the rear shock mount for one
micrors4guy is offline
Old 11-20-2013 | 02:39 PM
  #137
JayBee's Avatar
Exactly.
I just built mine and there isn't a hole anywhere for a roll over antenna. Strange...or maybe I'm missing something.
JayBee is offline
Old 11-20-2013 | 03:42 PM
  #138
dr_hfuhuhurr's Avatar
The circled bit isn't a hole for the rollover antenna?
That's not good.
dr_hfuhuhurr is offline
Old 11-21-2013 | 04:48 AM
  #139
Sixgears's Avatar
Any tips for building this? I am going to be doing so within the next week or two
Sixgears is offline
Old 11-21-2013 | 04:59 AM
  #140
That's not good.
Nope. That's where the al. Block for the chock screw goes in from the bottom
Old 11-21-2013 | 08:38 AM
  #141
Tron's Avatar
Nothing that I can think of other than JayBee's tip about a 0.3mm shim under the pivot block. The build is very simple and the instructions really are great.
Easier build than the RM-01 I just built.
Max K's baseline setup for Super Stock and Mod can be found on Arn0's site:
http://www.petitrc.com/reglages/vbcr...nning_IIC2013/
Tron is offline
Old 11-21-2013 | 08:54 AM
  #142
Sixgears's Avatar
Nothing to ream/polish/deburr/file/sand (except for chassis obviously!)?
Sixgears is offline
Old 11-21-2013 | 08:58 AM
  #143
Tron's Avatar
I polished any surface that could create friction drag - but absolutely not necessary, just something I like to do.
Tron is offline
Old 11-21-2013 | 09:39 AM
  #144
JayBee's Avatar
Where has 'VBC Racing Shop' been; I haven't seen that rep on this thread in a while
JayBee is offline
Old 11-21-2013 | 10:36 AM
  #145
OVA's Avatar
OVA
Arent you the back up ...
OVA is offline
Old 11-21-2013 | 01:23 PM
  #146
JayBee's Avatar
Not exactly
JayBee is offline
Old 11-21-2013 | 02:17 PM
  #147
VBC, if you are following this thread, please make a shock mount with a rollover antenna. Or anyone out there in the hop-up world, that would be acceptable as well. Please don't make us run without our rollover antennas.
Old 11-21-2013 | 02:40 PM
  #148
RedBullFiXX's Avatar
Would the R5 shock mount bolt on
These cars do share an un-canny resemblence
RedBullFiXX is offline
Old 11-21-2013 | 03:07 PM
  #149
haywood's Avatar
+1
haywood is offline
Old 11-21-2013 | 03:28 PM
  #150
S.Stew's Avatar
Dave Johnson has a photo on his facebook showing his lightning 12 and it's got quite a tall rollover antenna on it. Maybe he can explain...?
S.Stew is offline
