New Xray parts in rcMart now~!!
XRAY New Parts of Various Model now in stock. (Some are for the 14' T4 so stay tuned)
XRAY Garphite Upper Deck 2.0mm For T4 14 #XR-301197
Click HERE for more info~
Xray Composite Servo Saver Set X-Stiff #XR-372503
Xray ECS Hudy Spring Steel Drive Shaft 52mm w/2mm Pins for T2 T3 T4 #XR-305330
Xray ECS Drive Shaft 50mm w/2mm Pins Hudy Spring Steel #XR-305331
Click HEREfor more info~
Xray Graphite Gear Differential Bevel & Satellite Gears for T3 T4 NT1 XB4 #XR-304931
Xray High-Performance Low Friction Kevlar Drive Belt Front 3 x 513mm #XR-305434
Xray Long Composite LiPo Battery Backstop (1+1) #XR-306184
Xray High-Performance Low Friction Kevlar Drive Belt Rear 3 x 189mm #XR-305447
Xray Rear Body Mount Set +1mm Height for T2 T3 T4 NT1 #XR-301333
Xray 4S Spring Set
Xray 4S Spring Set C =2.6 for T4 #XR-308286
Xray 4S Spring Set C =2.7 for T4 #XR-308276
Xray 4S Spring Set Progressive C=2.3-2.6 #XR-308263
Xray Aluminum Layshaft Bulkhead Closed Left / Right - Orange For T4 #XR-303056-O
Xray Anti-Roll Bar Rear 1.6mm For T4 #XR-303496
Xray Belt Tensioner Aluminum Set For T4 #XR-303071
Xray Ball End 4.9mm w/Thread 8mm - V2 2pcs #XR-302654
Xray 4S Spring Set
