TLR 8IGHT E 3.0 THREAD
#572
#578
I pretty much run the kit setup switching out the oils for TLR oils but I run 10 deg of kick in the front and a ride height of 27/25. Also, I run my servo saver tight with the alum servo saver arm and servo horn.
#580
Hi guys, got it yesterday ! What a nice buggy
Only build complaint was the rear diff case, not easy to put together ! I have a problem with the front suspension, it is not as smooth as the rear. Checked the shocks twice, silk smooth, when I put it on the tabs, it does not rebound smoothly...Is it the spring rate or the tabs ? I heard some guys sandblast their pins (noob here), is that the solution ?
Thanks DOHC
Only build complaint was the rear diff case, not easy to put together ! I have a problem with the front suspension, it is not as smooth as the rear. Checked the shocks twice, silk smooth, when I put it on the tabs, it does not rebound smoothly...Is it the spring rate or the tabs ? I heard some guys sandblast their pins (noob here), is that the solution ?Thanks DOHC
#581
Front shocks have been a 100% issue as I had the same problem. Easy fix is grab some plyers and squeeze tye turnbuckle links to form around the ball. This will loosen your turnbuckles and fix the problem.
As far as the hinge pins I know a lot that sand them. I did not and car is just fine. Give the car a few batteries run in and you will see it loosen a bit and become a dialed machine
#582
For anyone running the stock spur(43T), what kind of pinion are you running with a 1900(tekin)? I started with a 14t and the car just seemed flat
. I put a 15t on and it was MUCH better, but temps were creeping up(180-190) on the motor.
Or for people running the 45t metal, what pinion are you running? thinking about getting the metal one this weekend possibly.
. I put a 15t on and it was MUCH better, but temps were creeping up(180-190) on the motor. Or for people running the 45t metal, what pinion are you running? thinking about getting the metal one this weekend possibly.
#583
Thanks DOHC
#584
2Likes
